Test IAC
Old Feb 12, 2015 | 06:39 PM
Tobra's Avatar
Test IAC
03 lancer 2.0L Auto
If the car is running and I unplug IAC should the engine drop in rpm?
If I take the IAC out, leave it pluged in and turn key on the IAC moves out turn key off IAC moves in. Would this mean the IAC is working properly.
Having idle problem. It was idling high until I figured out that the throttle cable was to tight. So I lossened the cable now it idles to low, with a/c on its worse.
Old Feb 12, 2015 | 08:36 PM
jakermeister's Avatar
You can try pulling it out and cleaning it first. You might want to check your vacuum lines as well.
Old Feb 12, 2015 | 09:49 PM
Tobra's Avatar
Have cleaned IAC. Have also check all vacuum lines. I am going to put it back together and start it up and let it ecu relearn idle. I think that because the throttle cable was to tight that it threw off the ecu. Now that I loosened it off it has to relearn how to idle.
Old Feb 13, 2015 | 09:04 PM
It could be. What ever you do don't mess wit the BISS screw.
Old Feb 18, 2015 | 10:19 AM
Tobra's Avatar
IAC is working. I put a/c on and idle increased. My bad idle was caused by bad plugs, oil in plug tubes, throttle cable to tight.
Installed new plugs, valve gasket and plug tube seals, loosed throttle cable.
Car running smooth with no high idle.
Old Feb 20, 2015 | 05:24 PM
I'm glad you got it fixed. I need to do my valve cover gasket soon too.
4ukc
10
Dec 7, 2015 02:33 AM
CeeKayy
39
Jun 17, 2015 06:25 PM
mtschmidty
May 27, 2015 09:27 PM
10isace
Oct 8, 2014 01:23 PM
johnjonfenomeno
Jul 12, 2009 08:52 AM
