Shimmy
Old Mar 20, 2004 | 04:28 PM
StreetLancer's Avatar
Shimmy
K, quick rundown. I have been experiencing a minor "shimmy" feeling through the steering wheel for the past few months. I had diagnosed it as an imbalanced wheel, and knew that I would be replacing the wheels and tires within the month, so, left it alone. Now, it's still happening. Only happens at 69-71 MPH in a straight line. Any ideas on what the hell it could be?
Old Mar 20, 2004 | 04:41 PM
liquidlancer's Avatar
you go the new wheels ont he car now?
if they used those little stick on lead weights to balence the new ones one of em ight have fallen off throwing it off balence again thus making your wheel shake
Old Mar 20, 2004 | 05:17 PM
New wheels are on. No little lead things that I know of. It's the exact same shake as it was before, so, I'm assuming that it's something a little more complicated than balancing. Is it possibly the allignment?
Old Mar 20, 2004 | 11:23 PM
Cmon fellas.
Old Mar 23, 2004 | 09:07 PM
I took it back to discount today, and had them rebalance the hell out of em. Found out my passenger side was off by .5 oz. Took it up to 70, and the shimmy is still present, just not as blatant. Now, I think it's at the point that I'm just being paranoid.
Old Mar 23, 2004 | 09:12 PM
lancerozr's Avatar
that has been happening on my car for a while to... i need help with it also -- someone please help us!
- Rob
Old Mar 23, 2004 | 09:18 PM
I'm thinking it could possibly alignment.
Old Mar 23, 2004 | 09:19 PM
I meant might BE alignment. How many miles do you have?
Old Mar 23, 2004 | 09:43 PM
Souren's Avatar
Ill tell you exactly what its is. I had the same problem and i did all the things that you have done. It is one of the wheel bearings that are bad. If you have a warranty still then have it checked out.
Old Mar 23, 2004 | 09:52 PM
Okay, bring me up to speed... a what? How much to diagnose and fix, because I really don't feel like stripping off my aftermarket wheels so the dealer doesn't throw a fit.
Old Mar 23, 2004 | 10:01 PM
Souren's Avatar
Well allignment would have nothing to do with your car shakeing it would only make your car pull from side to side. If your car has been balanced and its still shimmying then it is most likely a wheel bearing. If you still have a warranty then it should be fixed for free. If not then your screwed because its gonna cost around $400 or so.
Old Mar 23, 2004 | 10:02 PM
Yikes. I'll give it a week.
Old Mar 23, 2004 | 10:04 PM
Souren's Avatar
dont give it too long because it will only get worse over time.
Old Mar 23, 2004 | 10:05 PM
Well, it doesn't make a whole lot of sense that it would change with the balancing/rotation of tires... Then again, it wouldn't make sense as an allignment problem.
Old Apr 5, 2004 | 01:30 PM
Danno's Avatar
check tire pressure, balance alignment...if its still doing it then check your toe angle and your camber
