2004 Sportback idle issue after TB change
Old Nov 2, 2015 | 11:37 AM
poleclimber63's Avatar
I just finished a TB/WP change and took my 2004 Sportback 2.4L (4G69) out for a run. It ran fine but when I came to a stop sign, the idle dropped to <300rpm and threatened to stall. Sitting in the driveway it sounds as smooth a sewing machine and it sounds smooth as it revs. When I put it in gear the revs dropped and I noticed the revs varied some before I moved the car... No CEL....
As this is my Wifes' car, she got in it this morning and drove out. She said it stalled at every corner and she headed straight home, as she didn't want to risk stalling it in the middle of an intersection!
A little confusing. I took my time when I did the TB job, followed the FSM, aligned the marks and used the sp tool to set the TB tension adjustment, checked it with the pin re-insertion etc etc. I cleaned everything including the crank position sensor---- and used a new serpentine belt etc. So, did I screw up somewhere? Has something coincidentally failed or what?? If the crank sensor fails the car shouldn't even run, correct? With no CEL, I see it as a crap shoot as to where to start...
On a side note, I did a TB/WP job on my sons' 2003 Eclipse (4G64) a couple of weeks ago (which was more of a pain due to space considerations) and it behaved a little funny for a few days, then was fine. Could this be the ECU "relearning" after the battery being disconnected for an extended period of time?? I ran into this when I did an engine replacement in my 4Runner last year--- it ran at high idle for approx. 30 min of operation (a couple of days) then run perfectly.... however, stalling seems a little extreme for this possibility!
Any input would be appreciated!!
lange333
Lancer Troubleshooting
Jun 1, 2018 01:27 PM
ever12
For Sale - Cars For Sale
Feb 21, 2017 08:16 PM
Toxin
15
Mar 14, 2009 12:47 PM
PSI_BOOST
Future Lancer / Evo Models
13
Dec 31, 2008 12:48 AM
Masaman
Jun 20, 2008 08:43 AM
