Possible Power/charging issue
I have been trying to figure out what's causing this issue. This issue has been around for about 3 months or so. Any and all feedback/help will be appreciated.
Symptoms
-headlights become dim when brake pedal is depressed
-headlights dim at random moments while driving ( a sort of flicker however, the headlights do not completely cut off)
- sometimes when placing transmission in neutral car loses power to the point where it almost dies
- sometimes with transmission in reverse car loses power to the point where it almost dies
-headlights, instrument panel & accessory lights get brighter when rpms are increased during idle
I couldn't quite figure out the issue since my alternator is about a year old and also is my battery. Checked terminals for damage or carbon build up. Ensured that connections were nice and tight.
Car was taken to two different mechanics, one used a machine which basically told read that my battery was bad & the other after some testing concluded that I needed to replace my alternator so I am very confused at this point. :shrug:
Any thoughts?
Here's an example of one of the symptoms i recorded. Once the rpms are increased as you can see the lights get brighter. They dim once the car is idling again.
Symptoms
Any thoughts?
Symptoms
Any thoughts?
Test - YouTube
Symptoms
Any thoughts?
Test - YouTube
blowngasket
Jul 1, 2015 09:16 AM
2manyAWDs
Aug 28, 2012 12:33 PM
EVO9MRNJ
Nov 3, 2009 09:32 PM
