jam nut holding on rear hub
Old May 8, 2016 | 09:11 AM
twrtoad's Avatar
hello,
I made a mistake and removed the nut holding the rear hub on, 4 lug drum brakes 2003 lancer es, I am trying to find the torque specs to put it back on. I have heard a couple different things, one guy said 28 lbs while spinning it and another guy said 130 lbs. The 130 seems like a lot but just want to make sure I get it set back right so I don't ruin the bearing. Hoping that someone has the torque procedure for the rear hub
thank you
Jim
Old May 8, 2016 | 09:17 AM
twrtoad's Avatar
i came across this picture, the nut is number 5, i just want to make sure thew number is right and not a misprint
Old May 8, 2016 | 01:29 PM
CrAnSwIcK's Avatar
that is the correct torque...it's quite a bit of torque, but it's one of those things, it's a big nut so it can handle the torque, and you don't want that **** coming off while you're driving...if you think that's a lot, the front axle nut is 181 ft-lbs...
Old May 8, 2016 | 06:40 PM
jimbo74's Avatar
Veteran: Air Force
that front axle nut if I remember correctly is actually like also +/- like 20 pounds as well.... my torque wrnch only goes up to 150
Old May 9, 2016 | 01:08 AM
CrAnSwIcK's Avatar
yeah, +/- 21...mine only goes to 150 as well, so I go max on the torque wrench, and then a tiny bit more with a breaker bar.
Old May 9, 2016 | 08:46 AM
RalliartN's Avatar
FYI, the bearing and shaft are designed so the axle nut torque does not apply a load to the rolling elements of the bearing, so don't worry about that - apply full torque.
Crans, for nuts like these, and flywheel bolts, I picked up a 1/2" beam style 250 lb-ft torque wrench off amazon.ca for cheap. Does the job, is accurate, and bulletproof.
MrEvo9Mong
12
Apr 22, 2018 04:16 PM
GG_EVO_IX
May 23, 2013 08:55 AM
Tip3r
Sep 17, 2012 10:32 PM
Jackson Machine
Jun 5, 2009 04:49 AM
