03 Lancer has NO.... I mean NO POWER when on pedal
Old Sep 26, 2016 | 06:31 PM
Pruetmic1's Avatar
03 lancer 2.0L manual trans, has no power when on the pedal, gains speed at snail pace. When taking off its almost like im in 5th gear, i mean it almost dies.... Ive let other people drive it to make sure its not how I drive but they say its a dog! vacuum is at 16in when idle, spark plugs are new and are at the right gap, air filter is clean, I swapped the maf with another lancer and nothing changed. it also wont idle right so i removed the iacv and cleaned it, nothing changed. i even replaced the lower catalytic converter thinking it was clogged and nothing changed. also my fuel economy sucks a big ole dong. somebody help ME!!!!!!!!!!!!!!!!!!!!!!!!
Old Sep 26, 2016 | 07:05 PM
.M.'s Avatar
.M.
Have you checked the fuel injectors/pump?
Old Sep 26, 2016 | 07:28 PM
Pruetmic1's Avatar
not yet, how would i exactly test fuel injectors? I know i can check fuel pressure for the pump!
Old Sep 26, 2016 | 08:15 PM
.M.'s Avatar
.M.
How many miles on the car? So I'm guessing it feels like half your motor is missing right?
I'd start by pulling one connection at a time. If there's no change, there's your answer. Possible that several are bad. Also... how about your coil packs? Have you checked or replaced those?
Old Sep 27, 2016 | 04:22 AM
Pruetmic1's Avatar
180k on the car, the coils didn't look horrible so i didnt replace them. When you say start pulling connection do you mean pulling injector connectors and if there's no change then I know it's an injector
Old Sep 27, 2016 | 05:08 AM
.M.'s Avatar
.M.
Correct. It's a good idea to replace the coil packs also due to the high mileage. Could be part of the problem.
Old Sep 27, 2016 | 06:38 AM
Pruetmic1's Avatar
ok ill give that a try, also I was thinking could part of the problem be the fuel pressure regulator? I havent checked the fuel pressure yet but i was just curious about it? also could you explain how a bad coil pack could cause this problem, im not doubting im just wondering? Like a short in the coil?
Old Sep 27, 2016 | 06:58 PM
Pruetmic1's Avatar
Changed the coils and no change, but i did check the fuel pressure and this came out of the bleed off tube! Ide say this isnt right, did i mention this car had sat for awhile before I bought it!
Fuel that came out of tank!<br/>
Old Sep 27, 2016 | 09:48 PM
CrAnSwIcK's Avatar
Orange Gatorade...cars use gasoline..
Old Sep 28, 2016 | 08:22 AM
Pruetmic1's Avatar
so it looks like I will be doing a lot of cleaning of the tank this week!
Old Sep 29, 2016 | 09:59 AM
Pruetmic1's Avatar
there are two gallons in a bucket that arent pictured<br/>
Old Oct 2, 2016 | 11:18 AM
Pruetmic1's Avatar
I emptied all the old fuel and put in new and it still doesn't get out of its own way. I wondered if it could be bad injectors? I need to mention that when driving at about 40 it kinda jerks forward a little bit, could it be a clogged injector that will come aunclogged a little bit at a time?
Old Oct 8, 2016 | 12:02 PM
Pruetmic1's Avatar
So I pulled the plugs out to do a compression check and found that two plugs were as clean as the day I put them in ther, so I started looking at the ignition, come to find out that the coil and wire for cylinder 2&3 was not firing. I had power and ground at the plug for the coil but no signal, after some Internet reserch I found that signal wire at the ecu and measured resisted, it was out of limits, I over layed and wire and it fired right up and purred like a kitten!
Old Oct 11, 2016 | 02:47 AM
jimbo74's Avatar
Veteran: Air Force
sounds like a fuel pump..... my old van wouldn't go above 35 mph..... for a long time......
replaced the fuel pump, and it has been fine since
CZ4A4B11
Sep 15, 2014 10:24 AM
woodc
Jun 16, 2005 06:46 PM
famous182
Apr 10, 2004 09:04 AM
cky3396
May 8, 2003 12:32 AM
