Lancer GLS 2003 not shifting, no power!!
Old Jan 10, 2017 | 09:32 AM
rossman's Avatar
Hi all,
Just new here. have no one to ask that could give me specific answer.
I bought a Lancer 2003 with CVT trans. First issue is delayed acceleration and no power uphill. I floored gas pedal and it takes seconds before it picks up speed. Second problem it doesnt change gear. ATF has been changed. Been to a mechanic and he seemed not sure what the problem is. I hope I could get a help through this forum.
Thanks a lot!
Old Jan 10, 2017 | 09:13 PM
CrAnSwIcK's Avatar
CVT's don't shift...the fact that it's gutless doesn't surprise me...but the band/belt could be slipping...
Old Jan 11, 2017 | 05:34 AM
rossman's Avatar
Thanks! I understand CVT's run smoothly that you don't feel its changing gears. but I am sure that I am stuck with first gear since I hear the engine roar and RPM sky rockets without speeding up.
N light flashes while on D. Diagnosed and found 1st gear and 2nd gear faults on the transmission. It also showed about ATF temperature fault.
Havent check the belts but I see vibration on the pulleys.
Old Jan 14, 2017 | 12:58 AM
CrAnSwIcK's Avatar
I'm not an expert on CVT's but it sounds like slipping, and if there are faults, then that's a dead giveaway...I would inspect the oil for quantity and condition...not too sure about the gearing faults, but it could be related to the abnormal oil condition.
The tracker
Lancer Troubleshooting
14
May 31, 2014 09:27 AM
GEVOVIII
Dec 29, 2010 05:48 PM
detroit pistins
Nov 24, 2008 10:40 AM
evolution_racer
For Sale - Cars For Sale
Mar 15, 2007 03:56 PM
EvoG8r
South Region
Mar 4, 2005 05:59 AM
