Ping ping!
Old Sep 15, 2017 | 09:55 PM
Grasshippy2017's Avatar
Ping ping!
I have a 2006 Lancer ES. It pings after ignition but then it stops. Didn't have this problem until after changing the belt. I have been using the 88 grade ethanol free fuel. It this the problem?
Old Sep 15, 2017 | 10:16 PM
Evo__Lee's Avatar
Im pretty sure it is you should be using minimum 93 oct! unless you're in Cali and stuck with 91
Old Sep 17, 2017 | 02:51 PM
4b11slayer's Avatar
Double check timing.
Run better fuel
Run a sea foam to clean carbon build up
Angel Of Mercy
40
Feb 19, 2004 07:09 AM
dperfect21
Dec 31, 2003 08:35 PM
