Engine ping
Old Dec 31, 2003 | 05:17 PM
dperfect21's Avatar
Engine ping
I just installed stage 1 and 2 from buschur. The car seems to be running fine but everytime I rev the engine, then let off the gas, I hear this really high pitched ping. This also happens after i shift. Sometimes it will make a couple of pings, its weird. Ive tried listening under the hood but its almost impossibe to tell where its coming from.Thats why Im thinking maybe it internal.
Ive talked to buschur about it and they said that I wouldnt be able to hear engine knock and if it was then my engine would be blown already. They told me it my might be boost leak, so we went over the boost gauge, controller, and IC piping fitting and they were all good. It might be nothing but I dont wanna drive a 30K car if Im doing alot of damage to it.
As I said ive got stage one and two. Buschurs S-AFCII settings. 91 octane and 6500 feet above sea level.
Does any one have a clue what could be making this noise?!?!?!
Old Dec 31, 2003 | 05:26 PM
MP5's Avatar
MP5
In Timeout
Re: Engine ping
Is your exhaust hitting the heat shield? the high shrill noise it makes is commonly mistaken for ping
Old Dec 31, 2003 | 07:45 PM
dperfect21's Avatar
Nope that cant be it because the exhaust was the last thing installed. I took it for a test drive before installing the exhaust and I was getting the same noise.
Old Dec 31, 2003 | 08:01 PM
90GSX-03EVO's Avatar
Possibly, in some strange and twisted way, could it be the 1G DSM bypass valve that is used?
I'm thinking that maybe it's sticking and since it is all metal in that area, maybe you are hearing a ping from metal-to-metal contact when you get off the throttle.
Other than that, I am stumped.
Old Dec 31, 2003 | 08:26 PM
dperfect21's Avatar
ill try listening closer to the 1g.. hopefully that is it. thanks
Old Dec 31, 2003 | 08:35 PM
If I just solved this problem, then I am the greatest internet tuner that the world has ever known.
Corbin09
17
Oct 24, 2014 09:12 AM
OneEyedJack
Sep 15, 2010 01:10 PM
wevo1985
15
Nov 1, 2008 03:41 PM
Noize
29
May 20, 2005 12:00 AM
Evo442
Feb 25, 2004 01:25 PM
