Turbocharged Lancer 08 DE possible fuel issues
Old Nov 26, 2017 | 01:19 PM
BoriCangri's Avatar
So I have a 2008 Lancer DE that is turbocharged and tuned. My car wont start. Battery is brand new so that shouldnt be the problem. I replaced the fuel pump and the fuel pump relay and the fuel pump isn’t sending fuel to the fuel rail. I pulled the hose out to see if it would at least spit out the fuel when i tried starting it but nothing. I dont even hear the usual humming noise from the fuel pump. Im guessing its something between the fuses or the pump. Please help!!
thanks in advance
Alberto
Old Nov 27, 2017 | 12:09 PM
Veronica's Avatar
Use a 12VDC lantern battery to power the pump directly.
Works? Wiring. Keep backtracking until you get to 12VDC...
Doesn't work? Replace pump & return defective unit.
Old Nov 27, 2017 | 08:14 PM
BoriCangri's Avatar
I replaced the fuel pump but i havent tried to power the old pump directly
Old Dec 1, 2017 | 12:47 PM
Veronica's Avatar
The thought is that you may have a defective new one as well...
Not impossible. It Is a quick way to eliminate it as a source of the problem.
Best is to use a multimeter and just start chasing voltages.
Old Dec 1, 2017 | 01:27 PM
BoriCangri's Avatar
I agree that its not impossible but i may have the worst luck ever to buy a defective part..
btw does the battery have to be 12v or can it be 9v because for some reason i cant seem to find a 12v battery..
Old Dec 1, 2017 | 01:30 PM
BoriCangri's Avatar
Old Dec 15, 2017 | 06:50 AM
BoriCangri's Avatar
Update!!
I manually powered the old fuel pump and the new one and they both worked. So the fuel pumps were not the problem. So I manually powered the fuel pump when I reinstalled it and was able to get some fuel to the fuel rail and was able to start the car after a few attempts. Once the car is running i realized the pump starts working again.. but only when the car is running. To my understanding when you turn the key the fuel pump is supposed to turn on for a couple of seconds before actually starting the car.. which my car is not doing. So i guess my problem is kinda solved. Just have to figure out why it doesnt activate before turning the key.
LOTL
For Sale - Cars For Sale
Jan 31, 2007 10:05 PM
Go_Lancer_Go
13
Apr 20, 2006 11:53 PM
Guntur
Australian Forum
Jan 9, 2005 05:56 AM
Boni
Lancer Aftermarket Forced Induction Tech
Aug 28, 2002 08:19 AM
