Low voltage on fuel injector
2014 Lancer, now cranks but no start. Fuel injector is not working, voltage test on the wire to injector result:
1. Key Off: 0v
2. Key On: 10v
3. Cranking: 10v.
Is this 10v normal? Where shall I look at? I can hear muffler pops twice. Thanks.
1. Key Off: 0v
2. Key On: 10v
3. Cranking: 10v.
If you hear multiple clicks on the fuse box when starting then your battery needs to be recharged or replaced. Check DTC's / fault to see if there's anything wrong..
hixlancer
Apr 10, 2019 10:18 AM
