Oil Separator for Engine
Old Mar 24, 2022 | 08:44 PM
ZMitsu's Avatar
5 Year Member
My Lancer burns about a quart of every 4K I put on it. A friend of mine that has been a Mechanic for 10 years says they have Oil Separator for motors, that can help with cutting down on the oil the motor burns. I'd like to try this, since over time it will clog up the Cat on the exhaust. . We both did a web search and could not find anything specifically for the Lancer. Has anyone else ever tried something like this?
On the Youtube Scotty Kilmer channel, he says Mitsu's use cheap piston rings, and that's why they burn oil. Not sure if I can afford a ring and piston job at the moment though.
Old Mar 25, 2022 | 08:58 AM
ViciousLSD's Avatar
i have used several small cheap ones. i set up mine to drain oil back to the oil pan. I like these
https://www.ebay.com/itm/30387753774...EAAOSwS9RgINAL
https://www.ebay.com/itm/175136291206
for bigger hoses(no drain hole)
https://www.ebay.com/itm/313743603008
Old Mar 28, 2022 | 08:17 PM
ZMitsu's Avatar
5 Year Member
Thanks I will check those out, and show my mechanic as well.
Biggy VIII
27
Aug 6, 2013 10:25 AM
cij911
14
Oct 4, 2009 06:09 PM
BlackOperative
Lancer Aftermarket Forced Induction Tech
10
Sep 24, 2008 11:29 PM
zmeli
16
Aug 3, 2004 07:41 AM
Kebin
Australian Forum
Feb 18, 2004 11:45 PM
