Oil consumption on new built engine. Checklist.
Old Jul 30, 2013 | 10:22 AM
Biggy VIII's Avatar
Hi mates!
I have experienced abnormal oil consumption on several new built engines (from max to min on the dipstick in 700 or less miles of city traffic driving) and wanted to ask what can be the reason of such consumption. May be you could help to work out a list of parts and procedures that should be checked or done to help diagnose and prevent that kind of oil consumption.
The last engine that has experienced such problems was built 2.3 using Wiseco 1400HD pistons in 4g63 block. Typical used PTW clearance is 0.0027-0.0039 (0.07-0.1mm), rings and ring gaps are always checked and set according to the piston manufacturer manual. Oil used - Motul 300V 10w40, changed every 3000miles.
There is no smoke during start-ups, free revving or full-throttle accelerations, and no signs of major oil leakage.
Please care to share any thoughts and versions that can help to find the root of the problem.
Old Jul 30, 2013 | 11:54 AM
TurboTravis's Avatar
Try a more traditional oil (say, Rotella 15w40).
My twin turbo Corvette used oil when using a similar 'boutique' oil as yours, and stopped when going to Rotella. NO OTHER CHANGES.
Old Jul 30, 2013 | 12:05 PM
Biggy VIII's Avatar
Isn't that Shell oil for diesel engines? What about mobil, castrol, agipl, liqui moly?
Old Jul 30, 2013 | 12:23 PM
meckert's Avatar
So the Motul is a synthetic rt? Did you break your motor in on non synthetic first? If not, likely your rings arent seating properly causing the oil consumption.
Old Jul 30, 2013 | 12:44 PM
Biggy VIII's Avatar
The engene was broken in on the same oil. I believe I noticed the increase of oil consumption over first hundreds of miles.
Old Jul 30, 2013 | 03:04 PM
todd6027's Avatar
do a cyl leakdown test , I always use either running in oil or mineral oil in a newly built engine for a least 500mls
Old Jul 30, 2013 | 03:13 PM
TeachersEvo's Avatar
Have you used Motul? When I switched FROM rotella TO Motul in my old Civic track car I had a significant DECREASE in oil consumption. Same grade to same grade.
My .02cents. I can't make a recommendation for your issue OP, sorry.
Old Jul 30, 2013 | 03:16 PM
Biggy VIII's Avatar
Leakdown test showed less then ~5% in each cylinder.
Old Jul 31, 2013 | 04:24 AM
todd6027's Avatar
then id be looking at the turbo
Old Jul 31, 2013 | 06:48 AM
No, I don't use or need a boutique oil for my application.
Old Jul 31, 2013 | 10:04 AM
What makes you say it is a boutique oil? I have not heard that term before. It is fairly standard in the EU from my understanding.
I would suggest you try it before you decide it is instantly inferior. Dismissal of something while claiming it is inferior gives you absolutely no logic/rational to stand upon. If you have some sort of evidence, data, or even an observation that backs up what you have said (e.g. valuable input for this thread) please share.
Old Jul 31, 2013 | 12:24 PM
KJ8003's Avatar
I've noticed a lot of motors built with the stroker pistons tend to use more oil than pistons with the full compression height and ring package.
Old Aug 1, 2013 | 01:18 PM
todd6027's Avatar
mine doesnt use any between changes or do any of the others ive built
Old Aug 1, 2013 | 01:20 PM
todd6027's Avatar
no its not
Old Aug 1, 2013 | 04:45 PM
Clueless.
1)I gave a real life example of how an oil swap reduced oil consumption.
2)I send out my CONVENTIONAL STORE BOUGHT OIL out to Blackstone on a regular basis to have it anyalized and it's PROVEN to work great in my engine that makes more power per CI then anything you've ever owned. You're not worth my time to get off of the couch to go get the most recent one and upload it. However I'll do you a favor and link you to the thread I posted here on EvoM a few years ago regarding the same subject-
https://www.evolutionm.net/forums/ev...rks-great.html
Keep pourin' that liquid gold, kid.
