Help with Gauges
Old May 22, 2004 | 06:22 PM
JoeFriday's Avatar
Help with Gauges
I've searched and found a bit of help but I still need some info. I took off my needles to change the stupid bulbs (before reading the comments on the cluster how to, D'oh!), (I have an OZ), and I didn't mark where my needles went. I got my spedo going good, and the tach is perfect (didn't touch it), but my Engine temp and fuel are screwed. Is there any wat to bring these back to original position or does it have to go back to mistu?
Old May 29, 2004 | 06:52 PM
Panther893's Avatar
when the car is off all of the needels are at 0, try it from there....
Old May 29, 2004 | 07:15 PM
TG LanceR's Avatar
To fix fuel you can also simply fill up your tank and push the needle to full..... Engine temperature though, I have no clue..... Good Luck!
Old May 29, 2004 | 08:21 PM
Panther893's Avatar
like i said, easiest way i think would be to put the needels on when the car is off that way u know what everything will be, 0.
Old Jun 1, 2004 | 04:46 PM
JoeFriday's Avatar
I did that with the spedometer and it didn't work. You have to put it on farther than zero. But I think I've got the fuel down.
Old Jun 1, 2004 | 05:51 PM
Panther893's Avatar
if it helps ill take a pic of my car with the power off so u can have a refference point...
Old Jun 1, 2004 | 08:19 PM
JoeFriday's Avatar
That'd be great man! Thanks!!!
