B&M fuel pressure guage!!
Old Jun 26, 2004 | 11:41 PM
hectik's Avatar
Talking B&M fuel pressure guage help!!
i just installed a b&m command flo fpr..i have the b&m psi gauge but need help on installing it..any volunteers?? been looking around but no luck yet.
Old Jun 26, 2004 | 11:44 PM
TeamNeXusOz's Avatar
didnt even know they made one for our car?...pics? cost?
Old Jun 26, 2004 | 11:46 PM
hectik's Avatar
just posted a pic...made for the eclipse.
Old Jun 26, 2004 | 11:53 PM
hectik's Avatar
another...still confused with that dam psi gauge
Old Jun 29, 2004 | 07:41 AM
hectik's Avatar
lol...i begining to think no one gives-a-sh*t about me and my gauge... or should i post this somewhere else?
Old Jun 29, 2004 | 08:18 AM
Boeturbolancer's Avatar
does the regulator have a spot to tap into it for the gauge or do you have to tee into a line?? What part number did you use... that looks like a perfect fit. Did you have to modify anything to get it in?
Old Jun 29, 2004 | 09:45 AM
HobieKopek's Avatar
Don't you usually T the fuel line on the high pressure side for FP gauge? I know that's how Defi recommended I do mine....which I haven't done yet.
Old Jun 29, 2004 | 04:17 PM
hectik's Avatar
nope, no spot for tap but boe, your right...it actually fit perfectly...but i had to cut the top of the stock FPR with a dremel,...sand it down, swap pressure spring... and and bolt it up...very easy actually..part # for the FPR-Command-Flo 46056 (mitsu turbo fpr)...part # for gauge- 46054
as far as putting a tee...putting it on the high pressure side, hmm..how would i go about doin that? (what fitting would be best ?)
sorry for horrible pics (camera phone) and long post...
oh btw..nice oz's you guys..
Old Jun 29, 2004 | 04:45 PM
whats the advantage of getting one...cost?
Old Jun 29, 2004 | 05:07 PM
hectik's Avatar
advantage is being able to control fuel pressure coming in. hence the pressure gauge and air/fuel meter. i paid about 135 for fpr and gauge. not so bad i think
Old Jun 30, 2004 | 07:26 AM
Be carefull when playing with the pressure. The car doesn't like to be played with too much... i did that back in my early days to lean it out a little when accelerating. If the piggy was around i'd have gotten that but the fpr can be used like this.
I didn't see till now that it was a capping type regulator. Is the regulator a rising rate setup?
Some info from my early days... i found taking pressure to around 28psi made the car run fine and when you got on it gave it an AFR of around 12.2-12.5:1 instead of 10-11:1. This made a huge difference in my pulls. Gave me about 10-15 hp in the mid range and about 3-5 peak.
Old Jun 30, 2004 | 06:32 PM
hectik's Avatar
nah, its not a rising rate...unfortunetly...but i will take your advice for it....i guess that is why i am so concerned with the correct installation of this psi gauge..so that way i can accurately monitor the fuel pressure...along with my a/f ratio meter
thanks again for the tips boe...that should definitley help me out when configuring the ratio i wanna achieve
10-15 hp in the mid range and about 3-5 peak. <--sounds good to me
Old Jul 1, 2004 | 07:43 AM
It definately made an improvement. Now i just use the piggy back to tune such issues. There is definately a lot of fuel in the lancer. Good luck
Old Jul 1, 2004 | 05:13 PM
hectik's Avatar
cool...piggy back is next on my list... can't wait....... as far as the gauge, imma give it a shot. i'll post results **crossing my fingers**
Old Jul 7, 2004 | 01:40 PM
HobieKopek's Avatar
What good does the gauge do if it's not on the high pressure side? I can't see the pics clearly so I'm not really getting where you're getting the reading from. I just cut my fuel line. I'll replace it with braided SS hose when I get a little scratch again.
EDIT: btw, slightly off topic, but what's normal idle fuel pressure on a stock lancer?
