Front Signal Lights Broken
Old Oct 15, 2002 | 06:14 AM
cnile51's Avatar
Any suggestions why?? i took my blue ones out and put stocc bacc in and now they dint work and my signal lights inside the odometer signal really fast.... any suggestions besides getting 2 new bulbs?
P.S. i installed short ram, strut bar rear sway bar and took out the ecu.... you think that may have affected anything??
NiLe C.
Old Oct 15, 2002 | 12:30 PM
pjal84's Avatar
You took out the ECU? As in the actual brains of the car in the behind the glove compartment? I'm doubting you did since the car is still running... As for the lights...just which ones exactly did you replace? You mention the odometer (as in the thing that tells the mileage of the car and it's an LCD) but you also mention (thread title) that your signal bulbs are burnt but you also say you have a really fast blinking which is associated with burned out or soon to be burned out bulbs in the light housings...
Old Oct 15, 2002 | 12:48 PM
dmorsk's Avatar
faster blink rate of turn signals is due to burned bulb- get 2 new ones
Old Oct 15, 2002 | 10:30 PM
pinoyesv6's Avatar
ok put the blue bulbs back iin. do they work? if yes then its most likely the other bulbs aer broke. if not then its not the bulb. check the socket, make sure you are getting good contact, check the harness, make sure that you arenn't shorting or have a loose wire or something..
