4g94 Oz Swap Into Mirage
Old Jun 9, 2005 | 10:56 AM
ZooRacer's Avatar
i do have a manual transmission and STOCK LANCER ECU (5spd) for sale if u need it for ur swap
Old Jun 9, 2005 | 12:23 PM
sethrice90's Avatar
Ecu
How much for the ecu shipped zip 74021 and thanks for the offer, got a trans for right now.
Old Jun 9, 2005 | 12:32 PM
Alchemist's Avatar
What engine was in your car originally? G93 1.8L? Best of luck and let us know if you need anything
Old Jun 9, 2005 | 01:26 PM
sethrice90's Avatar
Wink My Ball and chain
My engine is the 4g15 the 15 meaning 1.5l also another word for slow as ****, you can see why im swaping.
Old Jun 9, 2005 | 01:36 PM
Alchemist's Avatar
I was looking for something else and came across this. Hope it helps some:
https://www.evolutionm.net/forums/sh...t=knock+sensor
Old Jun 9, 2005 | 02:11 PM
Blacksheepdj's Avatar
I wonder if that 4G93 block is still sitting at my uncle's house? Might be at the junkyard already...
Old Jun 9, 2005 | 04:47 PM
sethrice90's Avatar
thanks I know adam and will be in contact with him soon, Just seein if you guys had some invaluble info and parts hook ups
Old Jun 9, 2005 | 05:39 PM
Z_Lancer_Man's Avatar
I have a stock 4g94 enhaust manifold
Old Jun 9, 2005 | 06:30 PM
HobieKopek's Avatar
I hope if/when he does the swap he at least puts on an aftermarket exhaust. If you need stock Lancer parts just holler. I have some stuff lying around and I know other people do too.
Old Jun 9, 2005 | 09:37 PM
sethrice90's Avatar
Im putting a chrome header on there for now, until turbo time.
Old Jun 10, 2005 | 01:18 PM
sethrice90's Avatar
Talking Pics coming Soon
Hopefully get my pics up soon, gotta put them up at mirageforums 2, need a few pics of the car first, so I can let you all in.
Old Jun 10, 2005 | 01:43 PM
Alchemist's Avatar
Do you plan on boosing (I presume you are)? What's the advantage of a G94 over a G93? The G93s are able to take more boost, are making more power because of it and the parts are more readily available.... right? I could be way off base here, but I'm just curious.
Old Jun 10, 2005 | 01:50 PM
GPTourer's Avatar
What are you (y'all) using for engine management for these turbo Lancer's? I'd imagine to get he most life out of something over 7psi you are going to need a standalone. I know that is awfully expensive, but yield better results then just an S-AFC.
Old Jun 10, 2005 | 04:45 PM
sethrice90's Avatar
The 94 has a lot better lower end, has a much higher torque capability, and the boosting secret is a decompression gasket lowering compression to 9.1 and only useing 7-9 psi, 7 on regular basis and 9 psi on show off times.
Old Jun 10, 2005 | 04:51 PM
Alchemist's Avatar
Ok, that's why I thought you'd be looking at a G94. Streetable and yet, trackable. Good times
