need a wrx guru
Old Aug 18, 2005 | 12:51 PM
dexterdizzle's Avatar
need a wrx guru
Ok. I have a couple questions about the scooby turbo, like a 02 wrx
What is the spec number. Is it a ihi or tdo4 or what?
Also is the turbo wategate adjustable. Like can I raise and lower the amount of psi.
And last what is the wastgate set at stock. I've heard it was 14 psi then I heard it was 7. ?
Old Aug 18, 2005 | 02:09 PM
AznX TL's Avatar
i think evodave use to mod. a wrx
Old Aug 18, 2005 | 02:16 PM
GinuwineEvo8's Avatar
td04 I believe ... Yes you can raise/lower the amount of boost on the car ...
Stock boost is peak @ 16 and taper to 14 ...
www.nasioc.com
Might wanna ask there .. Its been a few years since I've owned subbie ... =P
Old Aug 18, 2005 | 03:34 PM
JeffR116's Avatar
Stock turbo is an IHI. Either a VF34 or a VF39.
Old Aug 18, 2005 | 03:38 PM
ehh no way d00d keke... people upgrade to VF34's .. Cobb Stag 2.5 is a VF34, injectors, intercooler,etc ...
Old Aug 18, 2005 | 03:50 PM
SIC SIK SIX's Avatar
the wrx stock turbo is the TD04. max boost is at 14.5 at 3500 rpms and tapers to around 8 or 9 at redline. IHI VF39 is the stock turbo on usdm STI's. IHI VF34 is the turbo for JDM STI"S
Old Aug 18, 2005 | 03:58 PM
JeffR116's Avatar
Old Aug 18, 2005 | 05:46 PM
So is it set at 14 psi stock. or is that what the max could be. Not worried about the cabilities just yet. So an sti usdm is a ihi vf4. What about the usdm wrx non sti? thanks for the relys guys this is really helpful.
Old Aug 18, 2005 | 06:04 PM
The TD04 is the USDM stock wrx turbo and its stock max boost is at 14.5. you can use an mbc, but i would not set the boost higher than 16 to 16.5 psi w/ stock internals.
Old Aug 18, 2005 | 06:12 PM
Oh yeah I was cobb'd and boost would spike to 16/17 and then down to 14 again lol ..
Old Aug 18, 2005 | 07:32 PM
cool thanks guys. I just wanted to find out some more info on the turbo. Its going on my lancer lol. Im building a custom manifold for it to mate up to this turbo. Ill be running stage two basically on my stock internals so i dont want to over boost until i upgrade my internals.
Old Aug 18, 2005 | 09:42 PM
Arithmetic's Avatar
14.5psi @ 3500 and 9-8 psi @ redline (7k)... yikes!
How much HP is the stock turbo worth?
Old Aug 18, 2005 | 10:00 PM
thats why the wrx is a slug on the highway in stock form. you can get around 220-240ish whp. depending on the dyno. after that, the turbo is pretty much maxed out.
Old Aug 22, 2005 | 11:29 PM
mkg1948's Avatar
i had a wrx wagon w/ 230 whp, on a stock turbo, stock ic, turbo back exhaust and ecutek. stock turbo is 14.5 lbs, in 4th and 5th gears only. in 1st-3rd, the boost doesnt hit peak. the stock turbo is good for about 16.5 lbs, anything above that is probably above the efficiency range of the td04L. a vf34 or vf30 is a worthwhile upgrade for the stock turbo... what internal changes are you gonna make before you install the turbo on your lancer?
Old Aug 22, 2005 | 11:48 PM
thats where my questions came in. Im running stock internals for now. Thats why i was asking the stock psi because i am going to have to tune it down to not blow my engines. either a wastegate spring mod, read that aznflip did it on his 16g, or electronic boost controller set way low lol. I am going to be running the tdo4 from a 02 wrx evo8n intercooler. type s bov, greddy emanage, bigger injectors, wally 255 and custom turbo back exhaust.
Am i running in the dark here or os there light at the end ot the tunnel.
