DSM's (long)
Turbo: EVO III 16G with Ported turbine housing, 16G turbo install kit
Intake/Cooling: HKS super mega flow, GReddy Type S bov, GReddy FMIC with proper piping, Fluidyne Radiator,
Drivetrain: ACT 2100 clutch
Fuel/Fuel Management: Denso 660's, Aeromotive FPR, Apexi S-AFC-2
Electronics: APEX'i Turbo Timer, 52mm GReddy EGT and Boost Gauge
Exhaust: Buschur Racing 2.5-inch Exhaust, Buschur Racing 2.5-inch Downpipe, Evo III Exhaust Manifold Ported (7cm turbine housing)
Fixed a couple things. This was all from your site
and to tell you the truth I will probably buy from there if you guys are still around by then
I'm in the same boat..... Just bought a 1990 eclipse GSX as a daily driver for me and as a project drag car for the wife (she is from PA, go figure).
I have already dropped some $$ on it and it is getting close to being driveable.
Gatorade, how did you see classifieds on DSMtalk if you just registered? I have been registered now for a while and cant see anything.
btw - Speedomodel, that car looks great!
It's always great to pass a 1 or 2G DSM on the street that's been taken care of. My mechanic and I were just commenting the other day how every year there's fewer and fewer nice one's left. Now you need to convince Robi to create the ultimate 1G suspension for us.
ha, if Robi got his hands on it I'd be so broke.... I already put KYB AGX's w/ Tein springs, SS brake lines, ST rear sway bar, evo9 wheels & tires... handles good for a street car.
Fixed leaking capacitors on ECU and got it socketed... got a built engine in it already (from previous owner), 2.5k on it since the rebuild. Balance and blue printed. Wiseco 8:3.1 pistons, bored .20 over, eagle rods, arp bolts (head,rods, main) balance shafts removed, MLS head gasket, new exhaust vavles, 3-angle vavle job... sound good?
n
n
Right on. That motor sounds stout, and I'm sure Buschur will know which turbo is right for you. If it hasn't already been done, I'd get TRE to rebuild the transmission and also swap in a 4-bolt rear-end.
http://www.dsmtuners.com/classifieds/
I've got a 94 Talon turbo as my daily driver. It's completely stock with less than 80k miles, fully loaded, 5-spd. Not sure how much longer I am going to keep it, but it's a nice little ride.
