Disappointing Dyno Results....
Just dynoed my '05 STi had Mach V the other day. The results were pretty heartbreaking.
Most stock STis are dynoing in the 240-250 whp and 250 lb/ft tq range, according to Dan. I have a Cobb Stage 1 ECU tune anda a K&N drop-in right now....not exactly setting the world on fire with mods, but nonetheless....
I had 3 pulls. My best pull was appr. 243 whp and 272 lb/ft tq. Here are the results of the pulls. Any comments/suggestions as to why my numbers could be so low? Sorry about the bottom two photos. I don't have a flat-panel scanner where I could scan the sheet.
You are 20+ ft lbs up on TQ which is GREAT....You really would need to compare curves, but my guess is that you are getting knock and pulling timing on the upper end....Did you log boost or AFR or knock ? If not do so and re-post...
Right now I'm running the Stage 1 93 Octane program. If crappy gas is an issue, would it be more beneficial to run a Stage 1 91 Octane program instead?
No, I haven't logged anything. I just got my car dynoed. They could've done an air/fuel analysis, but I figured Cobb runs rich anyway, so I really didn't find it necessary to do so.
My recommendation would be to contact jestrtuning....
jestrtuning@gmail.com
Sinister,
Definitely go with a TBE with a custom tune by Jestr. You'll be extremely happy with the gains to be had with two minor upgrades. Ever think about running meth injection as well?
Oh, no doubt! I totally agree. I didn't even plan on dynoing the car. If I had, I would've brought the AccessPORT along with me. It was sort of "on a whim."
