Little Yellow beast is back
Old May 30, 2007 | 04:09 AM
94AWDcoupe's Avatar
Brad Brooks works his AEM majic on shredder for a few hours saturday. straight 93 octane results were not so hot. this spearco core is not very good for straight pump. it does not remove enough heat. and heat soaked too easy. Best was about 380whp at 20 psi. when intake temps rose above 120 knock reared its head. turning on the meth and intake temps dropped to 65. now thats more like it. made 409 at 20psi. then 447 at 24psi. 475 at 26psi. 507 at 28psi. and finally 524 at 30psi. then the mishap gremlin jumped in the game. the cam/crank connector popped off and caused a massive backfire. unfortunately the head lifted and blew the head gasket.
Installed new factory metal gasket, arp studs.
Picking up where we left off. Every click on the boost controller netted nice gains. At 34psi she laid down 597whp/516tq. This is with boost increased at higher rpms to limit the torque a little. Not wanting to stop 3hp shy of 600 we set the boost to 35. Problem with this is the 3.5 bar map only reads to 35psi. So if the boost goes over 35psi the boost controller doesn't try to compensate because it still thinks we are at 35psi. So for an unknown boost level she layed down a very pretty 622whp/567tq. no knock. This is on 93 octane and alkycontrol meth injection. Torque monster.
here is a rundown on the setup:
shelf stock JE 8.5-1 stroker pistons
eagle rods
factory mitsu 100mm crank, nitrided
7 bolt block with balance shafts for smoothness.
7 bolt head with intake ports widened to match 1g port width.
cyclone dual runner intake epoxy filled to reduce port height to match 7bolt
(lots of work to make cyclone work on 2g ports)
crower 414 cams
880cc injectors, alkycontrol progressive kit, 15 +7
evo8 valves, evo8 springs and retainers
mild street port by jerry
2g manifold with adapter to mount GT35RLS (.63hot)
tial 38mm gate
3 inch exhaust with quiet magnaflow muffler
AEM tuned, boost controlled
best hp on old setup was 567/511. it was sick fast at that level.
Brad Brooks is the man. His tuning skills are second to none.
The last setup was a 2.4 6 bolt 7.7-1 pistons, no balance shafts and 6 bolt head. no other changes. I believe the 7 bolt stuff is better design than 6 bolt. so I did the worlds first 7 bolt swap.
I also tryed to prove stock 7 bolt studs are up to the task. Unfotunately the cas connector pooped off during tuning, this causes an RPM spike, leading to fuel/spark cut. alky still flows causing a MAJOR lean backfire. It made 525/490 on the stock studs. I believe they would have held more. They were not stretched when inspected. Head shows signs of lifting on all four cylinders near the exhaust side. I beleive the head would have lifted on the arps as well.
Car weighs 2565 with roll bar, full interior, a/c . Car drives smooth and quiet.
Old May 30, 2007 | 04:11 AM
TURBevO8's Avatar
That is freakin' awesome!!! I had a '93 Eagle Summit for years and years till last winter. I think it was around 95whp though.
Old May 30, 2007 | 04:33 AM
dadriva's Avatar
Sweetness. I'd love to have one of those!
Old May 30, 2007 | 07:37 AM
antilag_200's Avatar
now thats what I am talking about
excellent car, one of my close friends has the same year as you , he currently ran 12.18 and 119 with a small 20g. He has since bought my old T70 set up . IT WILL be fun to see what it does with the T70 and a 2.4 long rod motor
good luck with your car and
Old May 31, 2007 | 05:52 AM
PPI's Avatar
PPI
Nice, looks like a real fun car!
94AWDcoupe
Jul 14, 2023 08:35 AM
94AWDcoupe
Sep 27, 2016 09:53 AM
94AWDcoupe
16
Dec 18, 2013 08:19 PM
94AWDcoupe
For Sale - Part Outs
71
Oct 31, 2008 08:07 AM
94AWDcoupe
57
Jul 12, 2007 03:43 PM
