Ford Focus RS
Old Jul 8, 2008 | 04:04 PM
ak47po's Avatar
Exclamation Ford Focus RS
General specifications
Country of origin United States
Numbers built N/A
Introduced 2009
Engine
Configuration Duratec RS Straight 5
Location Front, transversely mounted
Construction aluminum alloy block and head
Displacement 2.522 liter / 153.9 cu in
Bore / Stroke 83.0 mm (3.3 in) / 93.2 mm (3.7 in)
Compression 9.0:1
Valvetrain 4 valves / cylinder, DOHC
Fuel feed Fuel injection
Aspiration KKK Turbo
Performance figures
Power 300 bhp / 224 KW
Torque 410 Nm / 302 ft lbs
BHP/Liter 119 bhp / liter
0-60 mph 5.9 s
The legendary Ford RS performance car brand is returning in the shape of the exciting new Ford Focus RS, which will be previewed on July 22 at the 2008 London International Motor Show. The new Focus RS will go on sale in early 2009 and is being created by a small team of dedicated engineers, under the direction of Jost Capito, Ford of Europe’s Vehicle Line Director for Performance Vehicles. For performance road car enthusiasts, the new model will mark a welcome return for the Ford RS badge. This will be the second Focus model to carry the RS mantle and promises another exciting chapter in an exciting 40-year story that began in Germany in the late 1960s and gained momentum across Europe with the launch of the 1970 Escort RS1600. Capito said: ''We want the new Focus RS to be a serious high performance car – as much a car for driving enthusiasts as the one before it and classic Ford RS models of the past. We’re staying true to the core RS principles of an exciting, yet affordable performance road car you can live with every day.''
Before it even turns a wheel, the new Focus RS exudes the presence, sporty style and lowered, ‘meaner’ appearance expected of a genuine Ford RS. Overt performance styling details mix with subtle revisions to create a planted, powerful stance and the promise of an exciting drive. The London show car previews the design intent for a final production vehicle, though as development work continues, some final details may change before volume production begins. The vehicle is finished in a special bright green paint with inlaid metallic flake, a striking, modern interpretation of the 1970s Le Mans Green of the Escort RS1600 era. The vibrant exterior colour is contrasted with a number of performance styling details highlighted in gloss ‘piano black’, including the strip at the leading edge of the bonnet, the deep housings for the integrated front fog lamps and door mirrors with integrated side indicators.
Front and rear quarter panels have been revised to incorporate wider wheel arches and a wider track, complemented by revised, deeper side rocker mouldings. In another visual reminder of the car’s performance potential, triangular, RS-badged vents sit behind the front wheel arches. Two classic-style bonnet louvres are both a styling hint at the power beneath and a practical requirement, maintaining correct system temperatures. The completely new front bumper design for Focus RS incorporates a deep front airdam with a large, mesh lower grille in an extended trapezoid. Stylish and practical, this prominent feature represents the latest Ford 'kinetic design' face and also is finished in piano black. Above, chromed xenon headlamps stand out like cat’s eyes and are framed by matt-black housings with unique additional vents running underneath. At the rear, a deep new rear bumper incorporates a large venturi tunnel to its lower edge with small vents at each corner of the bumper, emphasizing the car’s width. Two impressive chromed exhaust tailpipes sit each side of the black venturi, creating a purposeful rear view for the car. Above, a unique, twin-element, black RS rear spoiler sits at the Focus RS’ roofline, echoing both RS models of the past and the World Rally-winning Focus WRC that has been its inspiration.
Inside, this theme continues with a unique and appropriately performance-oriented interior, dominated by bespoke, sculpted Recaro high-performance sports seats, specially designed and trimmed for excellent support, even when driving enthusiastically. Each is colour-matched to the exterior, with ebony leather accents and ‘RS’ and ‘Recaro’ logos stitched into each backrest. Elsewhere, colour brings new excitement to the Focus interior, building on the sporty interior theme of Focus ST with more use of accents matched to the exterior colour, brushed aluminium highlights and overt performance styling. Even the rear seats feature higher side bolsters and a microfibre finish to echo those up front. The centre console is finished in a stylish gloss, carbon-look trim and metallic highlights abound, from air vents, door grab handles, switchgear and gearshift surround, to unique RS-branded scuff plates on the door sills. These highlights contrast with a black-trimmed roof lining, emphasising the sporty, cockpit feel. The driver is reminded this is a special Focus at every touch, with a gear lever finished with a six speed gear shift graphic in RS blue, a sporty, three-spoke steering wheel, finished with ‘Ford’ and ‘RS’ logos and even aluminium foot pedals. The performance driving environment is completed by three additional gauges from the Focus ST, including turbo pressure, sitting atop the centre console and angled toward the driver’s eyeline.
At the heart of the all-new Focus RS is a specially developed, turbocharged version of the Duratec 2.5-litre 5-cylinder engine. Significantly revised for high performance, this powerplant is targeting an impressive power output of 300PS and over 410Nm of torque, contributing to an excellent power-to-weight ratio. Such significant increases are not simply the result of altering engine management or boost pressure: starting with the Duratec 2.5-litre block, Ford RS engineers developed unique camshafts, a revised cylinder head and gasket and revised intake and exhaust manifold system for the car. Although the car is still in development, prior to its launch in early 2009, early performance testing indicates a 0-100km/h (0-62mph) time of under six seconds.
Throughout Focus RS’ development, Capito and his team have been keeping a sharp focus on creating a car that delivers excellent performance and traction. Various innovations, developed as a result of customer feedback from previous performance Fords, have allowed engineers to keep the new Focus RS as front-wheel drive, with a limited-slip differential, while still achieving demanding targets for traction, handling and steering. The new Ford Focus RS is equipped with an innovative front suspension system known as a ‘RevoKnuckle’, which is designed to reduce unwanted steering disturbance and torque steer, the impact of torque on steering in front-wheel driven vehicles. Torque steer occurs during hard acceleration, cornering or driving on uneven surfaces, when torque on the driven wheels exceeds grips levels. It is characterised by sudden turning force on the steering wheel and can be exacerbated by vehicles with wide tyres and limited-slip differentials. In Focus RS, the RevoKnuckle works in conjunction with a Quaife Automatic Torque Biasing limited-slip differential. Ford Team RS engineers have worked closely with Ford's Advanced Research Centre in Aachen, Germany to develop the RevoKnuckle technology specifically for the high performance Focus RS. It allows the simplicity of a traditional McPherson strut arrangement, but with geometry settings that minimize steering disturbances and torque steer, principally a reduction in steering offset.
A genuine Focus RS must maintain and enhance the reputation for responsive, precise handling for which Focus is acclaimed and considerable engineering effort has ensured that the new Focus RS will do just that. Driving quality developments for Focus RS include a 40mm wider track, stronger, longer driveshafts, revised springs and dampers and a thicker, longer rear anti-roll bar. At the same time, the steering system has been retuned to provide an even sharper steering response and very precise feedback. Brakes also have been uprated, with 336mm ventilated front discs and 300mm rear discs generating vice-like stopping power on road or track. Large calipers peek out from behind unique 19-inch wheels, wrapped in 235/35 low profile Continental tyres. A special version of Ford’s ESP system has also been developed for Focus RS, designed to allow a very sporty driving style before activating. Intensive work to refine the natural handling abilities of the car has allowed the ESP system to carry a full de-activation option for enthusiast drivers and especially for track use.
In creating the new Focus RS, Ford’s Team RS engineers have had to meet the same stringent targets for durability and reliability as those set for the rest of the Focus range. Despite its many bespoke engineering and styling elements, Focus RS will be built entirely on the main Focus production line in Saarlouis, Germany and offered with a standard Ford of Europe warranty.
Old Jul 8, 2008 | 04:09 PM
otter's Avatar
EvoM Administrator
The US still won't see it
Old Jul 8, 2008 | 06:42 PM
gaylantvr4's Avatar
I think it looks sharp besides the color.
Old Jul 8, 2008 | 06:47 PM
Kreeker's Avatar
sti anyone?
Old Jul 9, 2008 | 11:49 AM
griplimited's Avatar
Colin McRae would of steered this into victory for WRC
Old Jul 9, 2008 | 11:52 AM
VincentX's Avatar
Originally Posted by Kreeker
sti anyone?
No. The only similarity here is that they are both hatchbacks.
With FWD? No.
Old Jul 9, 2008 | 11:56 AM
05graphiteMR's Avatar
they are AWD, not FWD. thats part of why they won't bring it here. one is cost, they don't think it will sell because of higher cost. and 2 they think it will take sales away from the mustang. if this came here i would seriously contemplate getting one
Old Jul 9, 2008 | 12:01 PM
VincentX's Avatar
Did you read the first post? According to the article it's FWD.
Old Jul 9, 2008 | 12:12 PM
max2evoix's Avatar
thats pretty hot being thats a ford
Old Jul 9, 2008 | 03:10 PM
lysy82's Avatar
i would get one Focus in europe looks almost like this right now!!this one has front channged and has a body kit
Old Jul 9, 2008 | 03:39 PM
VincentX's Avatar
The European Focus looks so much better than the US one.
Old Jul 9, 2008 | 03:49 PM
ksattic's Avatar
I am surprised the 0-60 time (5.9s) is the same as the older RS since this car develops 300bhp and the older one 225 (I owned one before the VIII). LOVED that car.
I am also surprised that Ford once again decided to go FWD, after so much talk about the new RS being AWD. The Quaife is an amazing piece of kit though - the original RS would out-handle a WRX with ease.
Old Jul 9, 2008 | 03:50 PM
t4g63's Avatar
These are FWD, I've seen the previous version (2k7 or 2k8) it is sold in Mexico and being in the border I had a chance of checking one out at the dealership. The car looked pretty neat and sported recaro's along with an appealing body...not to mention it is turbocharged and as I recall they're 5cyl. I think it's called focus ST.
Old Jul 9, 2008 | 03:59 PM
ksattic's Avatar
The version you saw in Mexico was probably the new ST, which also has a 5 cylinder engine with turbo, but is not an RS.
ak47po
19
Mar 3, 2010 01:23 PM
ak47po
Dec 8, 2009 08:32 PM
ak47po
12
Mar 14, 2009 04:47 PM
ak47po
18
Dec 9, 2007 01:52 PM
mdaj
21
Feb 22, 2005 12:24 PM
