2010 Hyundai Genesis Coupe
Gosh I hope not.
Edit: In the pics from the tuner invite, I see a guy in a Forced Performance T Shirt - hrmmmmm? Thoughts FP?
Found Specs:
GENESIS COUPE SPECIFICATIONS
-- Configuration: Front engine, rear-wheel drive
-- Wheelbase: 2820 mm / 111.0 inches
-- Overall length: 4630 mm / 182.3 inches
-- Overall width: 1865 mm / 73.4 inches
-- Overall height: 1380 mm / 54.3 inches
-- Wheels: 18-inch or 19-inch five-spoke
-- Engine types: 3.8-liter V6 or 2.0-liter 4-cylinder turbo
-- Est. horsepower V6: 306 @ 6,000 rpm (regular fuel)
-- Est. horsepower V6: 310 @ 6,000 rpm (premium fuel)
-- Est. torque V6: 263 lb. ft. @ 4,700 rpm (regular and premium fuel)
-- Est. horsepower 2.0t: 212 @ 6,000 rpm (regular fuel)
-- Est. horsepower 2.0t: 223 @ 6,000 rpm (premium fuel)
-- Est. torque 2.0t: 217 lb. ft. @ 2,500 rpm (regular and premium fuel)
-- Block & head materials: aluminum for both engines
-- Valvetrain: DOHC for both engines
-- Valve timing: continuously variable valve timing for both engines
(Dual for 2.0t)
-- Estimated 0-60 mph V6: under 6 seconds
-- Transmission types: 6-speed manual, 5-speed automatic (4-cylinder) or
6-speed manual, 6-speed automatic (V6)
-- Front brakes: 12.6-inch (standard) 13.4-inch (Brembo package)
-- Rear brakes: 12.4-inch (standard) 13.0-inch (Brembo package)
-- Front calipers: single piston floating (standard), monobloc
four-piston (Brembo package)
-- Rear calipers: single piston floating (standard) monobloc four-piston
(Brembo package)
-- Limited slip differential (Optional)
-- Est. top speed: 149 mph (V6), 137 mph (2.0t)
-- Base curb weight: 3549 lbs. (V6); 3439 lbs. (4-cylinder)
Found Specs:
(Dual for 2.0t)
(Brembo package)
Yea old news for sure............
A big Wig at Hyundia in a car mag about 3-4 months ago said that the internals are good for 28+psi stock, and said it was made that way with the "tooners" in mind.
That and a stock lsd,, and you young "tooners" are going to have a fast , fun, cheap car!!!!!!
Nice link Evoish2wish guy,,,,,,,,,,
Too bad the Zf tranny is only avaliable in the v-6... always has to be somthing.
The 6 speed zf auto is the same used in the BMW 135, and 335's I believe.
And if thats the case,, that v-6 with the auto is going to be a fine car to have.
Keyless push button start, HID's, and a lsd,,, for under $27iish?
Plus a 100k warrenty,, I think they have a winner, for a guy who wants to keep a car for a long time, andf not modd it.
I'm kind of disappointed with the final production design. It is waaaay toned down from the aggressive conecpt design. I expected it to change a little bit, but this coupe looks very bland compared to the concept.
If you changed out the front bumper/sideskirt/hood the car would be pretty similar. The cost of producing headlights in the fashion of the concept would be $$$$.
AutoMotoSports
Automotosports - Illinois
335
Feb 19, 2010 06:12 AM
Clark_Kent
92
Mar 23, 2009 07:37 PM
