Bmw x6 m
Old Apr 10, 2009 | 05:17 PM
ak47po's Avatar
Talking Bmw x6 m
General specifications
Country of origin Germany
Numbers built N/A
Introduced 2009
Introduced at 2009 New York International Auto Show
Engine
Configuration 90º V 8
Location Front, longitudinally mounted
Construction aluminum block and head
Displacement 4.395 liter / 268.2 cu in
Bore / Stroke 89.0 mm (3.5 in) / 88.3 mm (3.5 in)
Compression 9.3:1
Valvetrain 4 valves / cylinder, DOHC
Fuel feed Fuel Injection
Aspiration Twin Turbo
Drivetrain
Chassis/body unitary steel
Front suspension double wishbones
Rear suspension Multi-link
Steering rack-and-pinion, power assisted
Brakes vented discs, all-round, ABS
Gearbox 6 speed Automatic
Drive All wheel drive
Dimensions
Weight 2380 kilo / 5247 lbs
Length / Width / Height 4876 mm (192 in) / 1983 mm (78.1 in) / 1684 mm (66.3 in)
Wheelbase / Track (fr/r) 2933 mm (115.5 in) / 1660 mm (65.4 in) / 1672 mm (65.8 in)
Performance figures
Power 555 bhp / 414 KW @ 6000 rpm
Torque 680 Nm / 502 ft lbs @ 1500 rpm
BHP/Liter 126 bhp / liter
Power to weight 0.23 bhp / kg
Top Speed 250 km/h / 155 mph
0-60 mph 4.6 s
Now the discerning customer has the opportunity to enjoy the unique high-performance character of a BMW M car also in the segment of BMW X models: The BMW X5 M and the BMW X6 M are the first all-wheel-drive models to offer the supreme performance, dynamic driving features, athletic design, and premium quality of a typical BMW M Car.
Both models are powered by a newly developed V8 high-performance engine delivering 408 kW/555 hp at an engine speed range between of 6,000 rpm from an engine capacity of 4,395 cc. The new M TwinPower Turbo engine is indeed the world's first power unit with a common exhaust manifold encompassing both rows of cylinders and featuring Twin Scroll Twin Turbo Technology.
BMW's intelligent xDrive all-wheel-drive system is naturally geared to the specific power and performance characteristics of the BMW X5 M and the BMW X6 M, just like Dynamic Performance Control also standard on both models. Interacting with the cars' special M suspension including Adaptive Drive and the newly developed Servotronic power steering, this ensures the driving behaviour so characteristic of a BMW M Car, combining unique driving stability with precisely controlled steering qualities all the way to the highest level of driving dynamics.
The BMW X5 M and the BMW X6 M set new standards in this segment of high-performance models in terms of acceleration, lateral dynamics, steering behaviour, stopping power, and efficiency. Both models accelerate to 100 km/h from a standstill in 4.7 seconds and stand out not only through the truly impressive delivery of power by the V8 turbo engine providing maximum torque of 680 Newton-metres or 501 lb-ft in the broad speed range between 1,500 and 5, 650 rpm, but also through the likewise smooth and consistent build-up of lateral forces meeting the highest requirements and the most dynamic level of performance in bends.
The exclusive character of both the BMW X5 M and the BMW X6 M results to a large extent from a level of driving performance never seen before even in this particular segment. Both models offer the ultimate in their segment in every respect, providing performance and dynamic driving reserves quite unique versus the competition and ensuring an experience of unlimited supremacy in everyday traffic.
The truly outstanding potential of both models comes out clearly in their looks and design, their joint DNA borne out by supreme performance on the road presented convincingly by the common design of the front end with its large air intakes.
The engine compartment lid, the front air dam and the headlight graphics carried over from the BMW X6 are identical in both cases. The proportions of the two cars, on the other hand, clearly differ through the variability of the BMW X5 M Sports Activity Vehicle as opposed to the dynamic qualities of the BMW X6 M Sports Activity Coupé.
Both the BMW X5 M and the BMW X6 M feature special gill intakes in the front side panels tailored to each model as well as individually designed 20-inch light-alloy rims.
The signs of distinction so typical of BMW M are likewise presented in individual style at the rear, in both cases confirming the outstanding dynamism of each model: The rear air dam on the BMW X6 M demonstrates particularly powerful presence, while the two dual tailpipes in the exhaust system surrounded in both cases by the rear air dam are again typical of BMW's M philosophy.
Compared with the "regular" BMW X5 and the BMW X6, the share of black plastic surfaces around the lower section of the body is reduced on both new models, giving even greater emphasis to the road going-orientation of the BMW X5 M and the BMW X6 M. Particularly the body elements fulfilling major functions in terms of aerodynamics and the flow of cooling air are clearly accentuated on both models.
Beyond these common features, both of these all-wheel-drive high-performance sports cars stand out clearly as unique models in their own right: The BMW X5 M clearly boasts its superior power and exclusivity at very first sight, while the BMW X6 M, in its unique design, alludes to fascinating driving dynamics and the car's athletic charisma.
Power and performance typical of BMW M is delivered by the power unit in both the BMW X5 M and the BMW X6 M by a new design and construction principle: The new M TwinPower Turbo with Twin Scroll Twin Turbo Technology and the exhaust manifold extending over both rows of cylinders patented by BMW offer absolutely extreme response and spontaneity, a linear build-up of engine power, and an unusually consistent torque curve.
The two turbochargers are positioned together with the catalytic converters in the V-section between the two rows of cylinders. The position of the intake and exhaust ducts provided in this way serves to reduce the length of the pipes and manifolds and increase their cross-section, with pressure losses on the exhaust side being significantly minimised in the process.
The joint flow of exhaust gas provided by the common manifold system connecting two cylinders at a time also ensures optimum gas throughput. The separation of exhaust flow is continued until the exhaust gas reaches the turbine wheel, building up ongoing pressure on the two Twin Scroll Turbochargers not impaired by any kind of counter-pressure.
With maximum charge pressure amounting to 1.5 bar, the use of Twin Scroll Twin Turbo Technology with its inter-cylinder exhaust manifold makes unique use of the turbocharging potential. Immediate, direct response to the gas pedal and truly exceptional pulling force from the engine starting at low speeds and continuing consistently to the highest load level characterise the new M TwinPower Turbo from BMW M GmbH. The truly impressive development of power ensured in this way is accompanied by fascinating engine sound accentuating the fast-revving engine characteristics and the linear build-up of power by a supreme acoustic effect typical of a BMW M Car.
Reflecting the superior power of the engine, the V8 power unit comes with a cooling system developed specifically for the two new models. One special feature in this context is the indirect intercooling effect serving to optimise performance under particularly dynamic driving conditions.
The new M TwinPower Turbo develops its outstanding output and performance with equally outstanding efficiency. In addition to direct Â*High Precision Injection, both the BMW X5 M and the BMW X6 M are equipped with a wide range of technologies from BMW Â*EfficientDynamics. Apart from Brake Energy Regeneration, these also include on-demand control of the electrical fuel pump, a detectable a/c compressor, as well as a volume flow-controlled supply of hydraulic fluid to the anti-roll system also operating specifically on demand.
Both models offer average fuel consumption in the EU test cycle of 13.9 litres/ 100 kilometres, equal to 20.3 mpg imp. Their CO2 rating is 325 grams per kilometre. And last but not least, the engine naturally fulfils all the requirements of the US LEV II standard as well as the EU5 requirements in Europe.
The suspension developed specifically for the BMW X5 M and the BMW X6 M with its double-track control arm front axle and Integral IV rear axle offers M-specific elastokinematics thanks to stiffer track control arm mounts and hydraulic tiebar mounts at the front as well as stiffer axle support mounts at the rear.
Both models come as standard with air suspension featuring self-levelling on the rear axle as well as Adaptive Drive with electronically controlled dampers (EDC) and active anti-roll stability. The special version of Adaptive Drive tailored to the requirements of BMW M also serves to lower the entire vehicle by 10 millimetres or 0.39" versus the "regular" BMW X5 and BMW X6 and incorÂ*porates stiffer carrier springs, modified auxiliary springs, three-way support mounts and damper control with reinforced connection to the body.
The special Servotronic steering developed for the BMW X5 M and the BMW X6 M provides individual steering assistance geared to the actual road speed of the vehicle. This allows comfortable parking manoeuvres with lower operating forces as well as exact feedback and a high standard of steering precision at higher speeds.
The philosophy so typical of BMW M naturally continues into the design and configuration of the driver's "workplace": Both of these all-wheel-drive high-performance sports cars come with a special M cockpit with the instrument cluster featuring a variable pre-warning field in the rev counter, specific vehicle function displays, and white display illumination. And both the BMW X5 M as well as the BMW X6 M boast M seats and an M leather steering wheel.
The driver's superior style of motoring is enhanced additionally by innovative driver assistance systems, both models fitted as standard with cruise control incorporating its own brake function. The wide range of optional features, in turn, includes Adaptive Headlights and a High-Beam Assistant.
Supplementing BMW Park Distance Control naturally featured as standard, there is also an optional back-up camera including its own very special Top View function.
Old Apr 10, 2009 | 07:57 PM
bracket's Avatar
I didn't read the article, but wtf is that thing? It looks like a BMW Aztec.
Old Apr 10, 2009 | 08:09 PM
localtoys73's Avatar
Ugly
Old Apr 11, 2009 | 01:01 PM
Sentinal's Avatar
Ugly on the outside but nice interior great engine and faster acceleration than our Evo's and Sti's
Old Apr 11, 2009 | 01:10 PM
romogst's Avatar
not my cup of tea, too much wheel gap.
Old Apr 11, 2009 | 01:18 PM
Kdash106's Avatar
wow.. i donno what that is.... is that a suv or??????????????
Old Apr 11, 2009 | 01:21 PM
2 Deep Motoring's Avatar
i actually like the way the x6 looks but its a very bold design so its either hit or miss
Old Apr 11, 2009 | 01:22 PM
bluebanana23's Avatar
supposed to be a sports activity coupe
Old Apr 11, 2009 | 05:09 PM
Sentinal's Avatar
I'd sport it. I'm gettin tired of evo's and sti's anyway lol that would be a great change of pace
Old Apr 11, 2009 | 05:13 PM
mirebih's Avatar
too ugly for my taste
Old Apr 13, 2009 | 02:12 PM
sizzflair's Avatar
I love it!
Old Apr 13, 2009 | 02:18 PM
max4rw's Avatar
I like it but probably very expensive!!! and for the money that it probably costs id rather get a z06
Old Apr 13, 2009 | 02:21 PM
krnkimchi702's Avatar
i hate the x6... and the "m" badge doesnt help
Old Apr 13, 2009 | 02:22 PM
newMRevoNyne's Avatar
Not feeling it.
Old Apr 13, 2009 | 02:28 PM
DizeLLx's Avatar
looks hot
