SmikeSVT - Wut?
Old Aug 7, 2009 | 07:41 AM
pwrofturbo's Avatar
What are the specs on that motor? ie rev limit, compression, etc?
Old Aug 7, 2009 | 08:21 AM
Smike's Avatar
http://myfordfocus.com/svt/
Engine
Configuration Zetec Straight 4
Location Front, transversely mounted
Construction cast iron block, aluminium head
Displacement 1.988 liter / 121.3 cu in
Bore / Stroke 84.8 mm (3.3 in) / 88.0 mm (3.5 in)
Valvetrain 4 valves / cylinder, DOHC
Fuel feed Sequential multi port Fuel Injection
Aspiration Naturally Aspirated
Compression Ratio: 10.2:1
Redline: 7200
After a retune, it will be 7600.
VVT on the intake.
otter's Avatar
EvoM Administrator
It's basically a Honda engine. 10.2:1 compression, rev limit at about 7500, reaches peak HP at 7000.
Old Aug 7, 2009 | 08:34 AM
Smike's Avatar
Basically, yes
Old Aug 7, 2009 | 09:20 AM
Blue8g's Avatar
i like.......i wanted one of those before i got the galant couldn't find any in my price range though
Old Aug 7, 2009 | 12:02 PM
Skylineracer's Avatar
From: Clifton New Jersey Lived: Daytona Beach, Florida Lived: Port Orange, Florida
good luck with the new car!
offtopic a neighbor in my apt. complex has what appears a rally speced focus in his garage i seen him drive it briefly once around the complex while i was cleaning the evo. its turbo sounds mean and i wonder if its awd. roll cage and all installed. even the driver name stickers on the side window LMAO.
Old Aug 7, 2009 | 12:54 PM
Smike's Avatar
Focus RS - had to have imported that. If its AWD its not a US spec car.
Old Aug 7, 2009 | 12:56 PM
ill try to find out one day what it is if i ever see him out with it again
Old Aug 7, 2009 | 02:38 PM
Smike's Avatar
Woot!
Old Aug 19, 2009 | 06:41 AM
Smike's Avatar
The updates - after a weekend of working on it with the help of otter its 95% ready for some AX testing. Rotors are still en-route. But all other areas have been addressed. Washed, waxed, realigned, new pads, lines, fluid, etc.
Even without adjustable camber or caster this car does have a healthy amount. I was at -1.7 up front and -1.5 in the rear with zero toe in the front and a combined .1 toe-in for the rear.
Painted the calipers black to clean them up some. Works like a charm.
And still representing you guys:
Old Aug 19, 2009 | 09:23 AM
Smike's Avatar
Also just called SVT, I own number 2704 of 4788. One of 589 that are black with the blue interior.
Old Aug 19, 2009 | 09:24 AM
c_reber's Avatar
You should get the HID headlights. I remembered seeing a focus way back that had HID's and thought it was a custom job, but then I found out later they were a factory option.
Old Aug 19, 2009 | 01:12 PM
Smike's Avatar
Yep, 03 and 04 had them. $600 for factories. I'm still searching for replacement ones. Or I might just get the ST170 versions above.
Old Aug 20, 2009 | 05:40 PM
dcpatters's Avatar
Looks great Smike. Who's Camaro in the pictures?
Old Aug 20, 2009 | 05:56 PM
otter's Avatar
EvoM Administrator
His brother's. It's a LS6 swap, if I recall correctly.
