RX7 4G63 swap
Old Nov 24, 2009 | 06:36 AM
travail's Avatar
RX7 4G63 swap
I was thinking of doing a 4G63 swap in to a rx7 FC. What RWD transmission can I run or should I make it AWD.
Old Nov 24, 2009 | 06:38 AM
garcias2k's Avatar
Funny, I just recently told my friend with an FD to do this. But this sounds like a lot of custom work.
Old Nov 24, 2009 | 06:39 AM
Murf's Avatar
I was looking into this also when my RX engine went poop. You have a few options but they need and adapt. plate to mate them up to the 4G. One is a mighty max.I don't remember which engine.
Old Nov 24, 2009 | 06:53 AM
travail's Avatar
So you mean the Mitsubishi Mighty Max D-50 with the 2.0L. I think they made them for 83 to 95.
Old Nov 24, 2009 | 06:55 AM
vtrice69's Avatar
wow... sounds like alot of work to make it 4wd. or you could do a 2jz swap and keep it rwd. i think the 2jz is superior engine anyway.
Old Nov 24, 2009 | 07:03 AM
travail's Avatar
I have seen that done before to. I like the 2JZ motor to. But you don't all ways see a 4G63 AWD Fc. I was looking in to a viper v10 swap to. The cost would be more though. I had 8K in to the last LT-1 T-56 FC swap I did.
Old Dec 6, 2009 | 02:19 PM
Renxo's Avatar
http://www.maperformance.com/the-map...ance-fdsm.html
Old Dec 6, 2009 | 02:26 PM
warstang27's Avatar
my brother and i were used to always talk about a 4g swap into a miata, while researched it we learned the fc trans mounts up directly to the mightymax block, then mount on the normal 6 bolt head to the block and call it a day, the hardest part is going to be mounting and wiring as with every engine swap
Old Dec 7, 2009 | 02:04 PM
_mcjonnyp's Avatar
MAP did it
youtube.com search MAP FDSM
bnr34rb26dett
Oct 31, 2015 09:45 PM
4g63evoeight
For Sale - Wheels / Tires
May 5, 2015 12:27 AM
4g63smokinall4s
24
Jun 6, 2013 11:15 AM
4g63smokinall4s
May 7, 2013 08:47 AM
travail
Nov 28, 2009 09:24 AM
