possible spun bearing?
this is a video of my friends tsi, he got a cyclone 4g63 put in and it was running like crap, then he noticed the timing belt was starting to strip and now it sounds like so..
http://www.youtube.com/watch?v=ip-uuQNIDjM
Could it be a spun bearing? if so what could we do to confirm it. or what else could it be?>
yea its bad, is there a way to check for a spun bearing>? the shop wanted 600 bucks to check, but maybe we can do it ourselves. It sucks because he barely put that motor in, if the timing was off could it cause it to spin a bearing?
Maybe he can find a g64 bock and put it on, it will be cheaper and keep it reliable at about 10psi
Ouch!!! Dude you deff have a big problem there...well its either something is banging all over the inside of your motor or you got one big F'n Rod knock going on inside. Put the car on jack stands and please drain oil first, and than pull oil pan off. If you see many shavings of metal on the bottom of the oil pan, than you might have a big problem which means spun bearing and damage to crank. Check each rod very carefully and take your time. Post up some pix
