a response to some misinformation
fwd cars perform better on the slalom....just cuz it almost got the same as the evo doesnt mean they handle the same on a track. hell the new focus svt outperformed the viper and zo6 on the salom but that doesnt mean ****...itll get raped on any track.
Exactly!
Re: Great Thread
Originally posted by Guack007
I have a question, does the evo use a form of VTEC? and if not can you add VTEC to the motor?
Originally posted by sblvro
it had a non-turbo variable valve timing MIVEC engine before but the turbo's became popular?
I was pretty sure the NEW evo vii or viii didnt and will probly not be using any type of VTEC. thnx for the reply. How much do you thnk it would be to add a vtec type system to the motor? Is it even that posible to do as an aftermarket project?
Re: a response to some misinformation
Originally posted by Griffin
Hmm - just wanted to clear a few things up.
Second:
The suspension package on the Hotchkis Celica is comercially available for a couple grand not 10. Also the BONE STOCK GTS with the gimpy rev limiter ran the slalom at 70.1, the EVO was 72.6... not really a huge difference especially considering all the technology on the EVO and the likely cost difference between the cars. BTW - Hotchkis is done prototyping and that Celica is for sale right now in case you guys want to see for yourselves
Second:
BMW's first ever FWD car... the Mini... did it with 67.6mph... thats with
110hp and 16" (or was it 15"??) WINTER tires...
http://www.roadandtrack.com/reviews/...leID=45&page=4
Can't find the result for Celica from R&T...
I believe HKS has some variable valve timing altering cam shafts available for the 4g63 evo engines. Didn't have much info on it though, saw it in an Options mag. I'm pretty sure you'd have to replace the ecu or have some type of piggy back unit to control it.
Originally posted by JT-KGY
And lets stop talking about celica for a moment... any of you toyota guys
know anything about the new supra???
Griffin
Re: Great Thread
Hey Griffin,
Great thread, I loved all the info on the W-8 and have learned more reading this thread and going to vw.com than I usually do here in the forums.
Hey Griffin,
As for adding VTEC or VVTI as an aftermarket add on... well... I'm gonna have to say No. They all use solenoid metered oil pressure to activate and I just don't see a way to plumb all that withou a redesigned head and Camshaft. Not to mention the engine management to run it would be a project of monumental proportions. One reason there are no US market drop in engine management systems for the 1ZZ or 2ZZ motors is that no-one in the aftermarket can afford to spend the money it would take to build the driver circuits for the Oil Control Valves and figure out how the heck to map em. Supposedly the Japanese Apexi Power FC can do it to some extent but i havent seen it so I can't say for certain.
BTW - I don't want to be a killjoy, but you should know that with the new legislation Cally's wonderfull Air ***** (read: CARB) pushed through and the gov just signed, when Mitsu brings the EVO over you may notice some significant power reductions and/or changes from the JDM version. This is bad news for all sports cars, but especially turbos with manual trannys, because its almost impoissible to properly regulate emissions between shifts on em.
it's not impossible, or even that ridiculous an idea...Toyota already uses VVT-i (not VVTL-i or VTEC, just variable cam timing, since variable lift really isn't necessary for power when you have a turbo) in their JDM Supra TT.
