Mid-Atlantic Region Includes DC, DE, MD, VA, WV.
EVO's passing emmisions.....
Old Apr 19, 2004 | 08:11 PM
Shahul X's Avatar
well, im gonna switch the hole TB exhaust before I go.... its a dead giveaway the way its so caked with soot.....
Ive had my EVO for 15 months, thats 9 more months before emmisions, but wanna do the cams within the next 6 months.... then 3 months later go to emmisions???? just wondering how everyone else does it.....
-shahul
Old Apr 20, 2004 | 04:53 AM
nastea1's Avatar
people down in virginia pass with aftermarket exhaust....
Old Apr 20, 2004 | 05:48 PM
Nad1370's Avatar
What kind of cams are you getting? and I thought New cars get their first emissions after 4 years? is MD diff.?
Old Apr 20, 2004 | 05:51 PM
Nad1370's Avatar
-shahul
Dude why don't you just clean your muffler tip with soap and water? It's much easier than taking the whole TB off
Old Apr 20, 2004 | 07:53 PM
Shahul X's Avatar
there is no way a TB will pass(in MD at least), no cats...come on.... its every 2 years, maybe 2.5 years?
I may just replace the dp and mid pipe..... not that the catback from there is a big deal, why risk it...?
Im leaning toward HKS 272/272.....
-Shahul
Old Apr 20, 2004 | 08:57 PM
Nad1370's Avatar
Man, I didin't know MD is that strict about emissions.
hks 272's are going to be perfect for your set up --MAXIMUN POWER--- and daily driving capabilities. best of both worlds.
I would hold of on the installation unless you know a guy who will install and un-intsall it for cheap. weigh your options:
Have fun with your cams for 3 months and worry about emissions? or save the extra money for labor and wait after your done with the test and have fun for 24 months.
I'd go with the latter. If money is not an option go for it but I see your getting married ( congratulations ) I'd save it and have patience. Evo's are a working project, If you rush it you might regret it. Have patience, and its the key to success into building the ultimate machine .
BTW a friend of mine has almost the same mods you got:
AMS fmic
forge recirc
AMS mbc
RC 720cc inj
Turbo back (catless)
open air intake
SAFC tuned at ams wide band (street tuned)
272 int/ex w/arp studs
ran 12.08-12.3's consistently 114-116mph ( best 11.92 )
100 octane 24psi 1.68-1.75 60fts on a stock clutch.
Old Apr 21, 2004 | 03:33 PM
Shahul X's Avatar
cool, thanks for the advice.....
so you all think I cant pass emmisions w/ the 272's eh....?
man.... that puts in a wrench to get a larger turbo also... I was looking at the AMS GT35R kit.....
Patience I have.... but not passing emmsions after that...oh well., thats like 3 years away...
-Shahul
Old Apr 22, 2004 | 01:16 AM
jbrennen's Avatar
If you have adjustable cam gears, you can advance the timing of the exhaust cam and retard the timing of the intake cam. This will give you less overlap between the cams, which could very well get your HC emissions low enough to pass a tailpipe sniffer test.
But if you do that, I wouldn't suggest driving any more than necessary with the cams like that.
Old Apr 22, 2004 | 02:57 PM
Shahul X's Avatar
silver surfer says -4, -1 (or 1.5)..... so your saying like do +1, -1?
-shahul
Old Apr 24, 2004 | 08:15 PM
RichJ's Avatar
I've heard that in MD they only do the OBD-II check on newer cars -- no sniffer. So long as you don't have things turned off in your program and you don't have a CEL, you should be fine. In NoVA, they do sniff every car. I bought my Evo used and it had to go through a two-speed idle test. Made me a little nervous with the bigger injectors, but it did fine. My cammed Camaro has passed as well in VA and its at least as lopey sounding as any 272-equipped Evo. Of course, standards are lower for a '95.
Old Apr 25, 2004 | 09:03 AM
nrcooled's Avatar
I just had mine emissions tested and since they didn't have anyway to do an AWD dyno they did a two speed idle test w/ the sniffer.
Get access to a WB02 sensor and check you EGT and A/F ratios then make sure that they are w/i spec of a stock EVO at idle and at 2500rpm
Your EGTs will tell you how your NOx and the A/F will let you know about the HCs
PM me if you need any more help. I learned all this while trying to get my 240 w/ SR smogged
Old Apr 25, 2004 | 09:06 AM
nrcooled's Avatar
Also don't forget that you can get your inspection and emissions anytime that you want. They will get you the stickers that you need.
So if you want to put your cams and turbo kit on next weekend (for example) just get you tests done now get your stickers then mod away!
Old Apr 25, 2004 | 06:25 PM
Shahul X's Avatar
lol, thanks nrcooled..... nice meeting you this past weekend also
-shahul
Old Apr 25, 2004 | 07:58 PM
RichJ's Avatar
What emissions sticker are you talking about? In NoVA, there is only a sticker for safety. The emissions test is just something that has to be in the state's computer before they'll issue your registration when it's up for renewal.
Old Apr 25, 2004 | 08:10 PM
jbrennen's Avatar
That's correct for the NoVA emissions testing program. There are limits on how far in advance of the registration renewal you can have the test done:
How far in advance can I have the emissions inspection done on my car?
You may have the emissions inspection done up to 90 days prior to your registration expiration date to apply for a two year vehicle registration. If the emissions inspection is done any earlier than 90 days prior to your registration expiration date, you may only be eligible for a one year vehicle registration.
From http://www.deq.state.va.us/mobile/mobfaq.html
