Midwest Region Includes IA, IL, IN, MI, MN, MO, WI, OH.
cam install price
Old May 24, 2005 | 02:10 PM
redevo58's Avatar
cam install price
I live in the chicagoland area and i am planning getting some cams, gears and headstuds installed and i was wondering where in the chicago land area did you get your cams installed and how much did you pay for the install.
Old May 24, 2005 | 02:21 PM
redevo561's Avatar
i would rec. ams since your in chicago area usually a cam install is from 200-350 head studs are usually a hour of labor if your getting the cams installed and studs at the same time
Old May 24, 2005 | 03:12 PM
Iceman2011's Avatar
redevo58 i am in the same boat as you. anyone got it done anywhere else than AMS
Old May 24, 2005 | 03:16 PM
blueo4's Avatar
there is an old saying that says "you get what you pay for!"
i say take em to AMS
Old May 24, 2005 | 04:12 PM
redevo58's Avatar
If you want maybe we can get try and get them installed at same place and see if they give us a discount or something for getting them done at the same place. let me know what you think.
Old May 24, 2005 | 04:56 PM
Iceman2011's Avatar
cam install
hey i called devotuning . adam that used to work for AMS owns it i believe . they said 280 installed for cams and studs. i wil ask them what they say if its two people. you getting cam gears too ?
Old May 25, 2005 | 08:27 AM
redevo58's Avatar
i will probably get the gears too.
Old May 25, 2005 | 08:30 AM
redevo58's Avatar
i see that you have a custom flash, do you know if cam gears are needed with al's flash?
Old May 25, 2005 | 08:35 AM
NapervilleEVO's Avatar
ask about for three with studs. i will not be getting gears. i also would need a street tune from adam. i am not sure if i am going to cam this month, but if the price is right i will.
Old May 25, 2005 | 08:38 AM
redevo58's Avatar
sounds good we might be able to get a better deal.
Old May 25, 2005 | 08:40 AM
redevo58's Avatar
napervilleEvo you rs wouldent happen to be red would it, because if it is i thought i saw your car acouple of times since i live in the same area.
Old May 25, 2005 | 09:21 AM
Iceman2011's Avatar
cam gears are not requires with any cams it is entirely up to you if you want. i called adam and have setup something for friday(6/3). let me know if that day works for you guys. if friday is good i can ask them then for 3 people.
Old May 25, 2005 | 10:21 AM
GOKOU's Avatar
You guys can go dyno at PW first
https://www.evolutionm.net/forums/sh...d.php?t=138491
I need head studs done but might be looking to do it myself since the labor cost will be more then the studs.
Old May 25, 2005 | 10:50 AM
Iceman2011's Avatar
i would probably get a dyno right after 6/3. do u know their regular rates if i walk in and just want a dyno
Old May 25, 2005 | 11:16 AM
rlazer5000's Avatar
Eric quoted me $350 for cams, cam gears, and headstuds at AMS. I decided to save some money and installed them with a few buddies. It took a little while, but definitely worth it. I know the head mechanic Tim over at AMS and they do awesome work, so if u want a quality install, take it to AMS.
