Midwest Region Includes IA, IL, IN, MI, MN, MO, WI, OH.
help swapping a fuel pump in evo
Old Oct 17, 2008 | 07:01 PM
jamevo8's Avatar
Ok... I finally gor it in by myself! what a great feeling!
Last edited by jamevo8; Oct 19, 2008 at 10:52 AM. Reason: I can do things if I put my mind to it
Old Oct 17, 2008 | 08:33 PM
huevosrancheros's Avatar
damn son , I was halfway to your place to help you.
Old Oct 17, 2008 | 08:40 PM
markymark1082's Avatar
haha. one of the most simple jobs on the evo. be glad you figured it out or you would have gotten a lot of heat.
Old Oct 18, 2008 | 09:03 AM
Brian's Avatar
pull the electrical part off?
Old Oct 18, 2008 | 10:43 AM
jamevo8's Avatar
unfortunatly I put the old one back in after I got it 1/2 way out. due to not being confident in my mechanic abilities. Will maybe try again tonight when I get home from work...Yes I had the electrical part off then started the car, pulled the lines off and teh 6mm bolts then lost confidence in myself
Old Oct 18, 2008 | 03:20 PM
BuLocal's Avatar
http://evomoto.com/tech_info.php?tPa...20d7024aa49e14
I would definately make sure you are near empty on the gas also................
Old Oct 18, 2008 | 08:06 PM
jamevo8's Avatar
Well I went further tonight.. although no success. I just couldnt get the black metal ring out of the tiny square for the life of me.... will try again tomorrow morn.. any suggestions?
Old Oct 18, 2008 | 08:11 PM
spdrcr456's Avatar
its a pain in the ***. don't force it. and keep working at it. rotate a little. eventually you will figure it out.
Old Oct 19, 2008 | 10:52 AM
jamevo8's Avatar
installed ! thanks everyone!!!
Old Oct 24, 2008 | 08:49 PM
LoCo4's Avatar
I've down 2 installs. Fairly simple. Will be doing a 3rd time with my brother's Evo.
