Midwest Region Includes IA, IL, IN, MI, MN, MO, WI, OH.
Help with HID conversion install for non-HID evos
Old Nov 11, 2008 | 08:13 PM
iota's Avatar
anyone who knows how to do this?
i just got my kit and have no idea how to install it. the how-to in the forum doesn't really help. if you have experience or know how to do it, please let me know! will pay you of course.
this is the kit i have:
http://www.xenonlink.com/product_inf...products_id=99
thanks.
Old Nov 11, 2008 | 08:19 PM
EvilutionIX's Avatar
it's too easy to do.... all you need to do is connect all the wires together and put the bulb in the projector... the hardest part is where to put the ballasts...
Old Nov 11, 2008 | 08:37 PM
oh yeah, i forgot... you have to remove your bumper to remove the headlights to get to the low beam bulbs. so this is the hardest part.
Old Nov 11, 2008 | 09:25 PM
iota's Avatar
where did you put the ballasts?
Old Nov 11, 2008 | 09:33 PM
newimportowner's Avatar
Mounted to the frame rail. on driver side behind ACD pump and on passenger side on frame rail behind oil cooler. you will have to take bumper skin off, but that is easy. I drilled a couple small holes for mounting on each rail. primed the holes and painted too. then used some self tapping screws. let me see if i can find the pics from mine.
Old Nov 11, 2008 | 09:48 PM
iota's Avatar
pics would be helpful. thanks!
Old Nov 11, 2008 | 09:49 PM
Here they come.
Old Nov 11, 2008 | 09:54 PM
Old Nov 11, 2008 | 09:56 PM
That should help. dont touch the bulbs what ever you do with your fingers.
Old Nov 11, 2008 | 10:06 PM
iota's Avatar
ok, that means i have to go buy a drill. i hope that place on the frame rail isn't too hard to access. did u have to move anything to get there?
this is very helpful. thanks a lot!
Old Nov 11, 2008 | 10:08 PM
you have to drop the oil cooler out of the way to mount them, but otherwise its pretty easy. good luck.
Old Nov 12, 2008 | 10:41 AM
inco9nito99's Avatar
Cleanest place to mount them is actually ON the headlamp (on the belly side like OEM fitment -there is even a nice spot meant for HID ballasts). This is how I installed my HID's on my RS.
Old Nov 12, 2008 | 10:45 AM
sharkm87's Avatar
luckily for me, i was able to use the stock ballasts and just change the bulbs !!...
you can let them dangle for now and find a spot later or zip tie it somewhere.
Old Nov 12, 2008 | 12:23 PM
BlckEvo8's Avatar
Dude cmon dangle??? Seriously?
Old Nov 12, 2008 | 12:25 PM
iota's Avatar
how did you secure it?
