VS Motorsports May Specials!!
VS Motorsports
1637-39 Barclay Boulevard
Buffalo Grove, IL 60089
Phone - 847-520-2990
Special Rates for Mondays & Tuesdays Only
$10.00 off Labor Rate
NO MINIMUM HOURS REQUIRED!
Standard Alignment $75.00 & Custom Alignments $90.00
Wednesday, Thursday, & Friday Rates:
$125.00 Mount & Balance + Standard Alignment
10% off Labor (2 Hours Minimum)
Engine:
** Need a part installed? VS Motorsports can perform all your install needs. We can perform a small install of an intake all the way to a full engine build to fulfill your every needs for your vehicle.
VS offers the following installs and Engine build:
Exhausts - Intakes - Shifters - Clutches - Flywheels - Headers - Downpipes - Turbo Chargers - Engine Swaps - Engine Builds (Pistons, Rods, Cams) - ECU Wiring - Electronic Tuning -and more**
Full Build
** VS Motorsports has a vast amount of experience with building the finest performance vehicles to hit the track. Check out Full VS Evo Race Car, Evo Sponsor Race Car, and our E46 M3 Race Car.
VS Offers the following in Build Services
- Safety Inspection (NASA or SCCA) - Full Race Vehicle Preparation -
Wheels/Tires
** Need your new rims and tires installed? Scared to have your rims scratched up and mangled? VS Motorsports has the best machines to prevent any damage to your wheels and tires. VS Motorsports uses Road Force Measurements System equipment for wheel balancing and we use an Automatic Swing-Arm Tire Changer with Patented Bead Press System for tire mounting. VS Motorsports can also provide you with the highest quality Rims and Tires for your needs.
VS Offers the following Wheel & Tire Services:
- Tire Mounting & Balancing - Wheel Alignment - Corner Balancing - Tire Rotation - Tire Repair -
Suspension
** VS Motorsports can perform all your suspension needs. From a daily driven street setup, to a full out Race car setup for either the track or the street.
VS Offers the following in Suspension services:
- Springs - Sway Bars - Coilovers - Brake Upgrades
Fabrication
** VS Motorsports can fabricate anything and everything you can imagine. VS Motorsports has the latest and greatest tools to fabricate intakes, roll cages, and any other accessory or part that you can imagine.
Some of the VS Fabricating Services:
- Custom Welding - Tube Bending -
Engine:
Full Build
Wheels/Tires
Suspension
Fabrication
