Service Packages & Specials @ Boostin Performance **Updated often**
**PM US FOR PRICING**
Boostin Performance Stage 3 Engine Package - The is our most popular engine, and can be built in 2.3L or 2.0L configurations with a choice of compression ranging from 9:1 to 10.5:1. A freshly decked, bored, and honed 4G63 block is the starting point and it only gets better from there. This short block comes balanced and fully assembled. This is the same engine that powers our "Red Demon" (8.62, best MPH 170) and Joey's "Junk Box" (9.1, best MPH 163.9)
SST Clutch Packages / SST Trans Tuning - With the latest developments in transmission tuning as well as SST clutch pack upgrades, we now offer upgrade packages for your SST powered Evo X MR, SE, or RalliArt. Turn your SST's sloppy shift into a nice, firm, strong shift.
Clutch Packages – These packages include the clutch, TOB, resurfacing of your flywheel, installation, gear oil for the t-case and transmission, and shop supplies. You can choose from Redline or AMS Oil gear oil for the transmission. Also includes ACD flush and bleed for all ACD cars.
Shifter Bushings – These are the rubber bushings on your shifter cables under the hood as well as the rubber mounts for the shifter base in the center console. We replace both under hood shifter bushings with billet aluminum bushings, as well as all 4 shifter base bushings (also in billet aluminum). This dramatically improves shift quality, and gets rid of all the extra play in the shifter.
Street - This kit replaces all (4) factory rubber bushings with polyurethane bushings. This keeps the rear end movement in check while keeping everything nice and quiet.
Race - This kit replaces the factory side diff mounts with solid aluminum ones, as well as removing the moustache bar and replacing it with a much lighter solid billet piece. This removes around 13 pounds of weight from the car, but due to the solid design, transfers more noise and vibration then the polyurethane option. The AMS Moustache Bar eliminator kit is used.
Powder/Ceramic coating - Finish off your project with the perfect final touch and protect your parts from heat soak. Powdercoat your intercooler piping, valve cover, or intake manifold with one of the hundreds of colors available. We love the wrinkle powdercoating, seen in the picture below.
When it comes to your exhaust components, that's where the ceramic coating comes into play (available in black or silver). Prices depend on the size of your part and the color/finish desired
Corner balancing & custom alignments available!
Corner balancing rate - $89/hr
Custom alignments - Starting at $110
Transmission Services
We can do everything from a basic rebuild to make your car shift like new again, to custom ratio transmission gearing. This custom gearing is designed to enhance quarter mile 60 foot times, and trap speeds, removing the need to shift into 5th.
Contact us for details! We have the knowledge and experience to help you build a transmission to fit your specific needs.
**PM US FOR PRICING/DETAILS**
- Manley TT I-beam rods
- BP spec. Wiseco HD pistons
- ARP main studs
- ACL race series rod and main bearings
- New OEM frontcase/oilpump
- AMS race balance shaft
- SST Transmission Reflashes
- Clutch pack upgrade with customized trans tune
- Comp Clutch Stage 2 (most cost effective clutch) - Evo 8/9/X
- ACT Heavy Duty Clutch Kit (best single disc clutch) - Evo 8/9/X
- Exedy Twin Disc Clutch Kit - Evo 8/9/X
- Quarter Master 8 Leg Race or Street Clutch Kit with Hydraulic TOB - Evo 8/9
- Evo 8/9/X
- Evo 8/9
- Evo 8/9
- Evo8/9
- Evo 8/9/X
- Evo 8 Kelford cams (264, 272, 276 or 280)
- Evo 9 Kelford cams (264, 272 or 280)
- Evo 8 GSC cams (S1, S2 or S3)
- Evo 9 GSC cams (S1, S2 or S3)
- Evo X - PM for details
- ** MAP Dog point Head Studs**
- **Beehive Valve Springs**
- Evo 8/9/X/RalliArt ECU reflashes
- DSM Tuning packages
- AEM EMS Tuning
- DSMLink Tuning
- Powder Coating
- Ceramic coating (high temperature resistance)
lol, thx Gamble
Even though we've listed Evo specific specials here since it's an Evo site, we offer a lot of services for all makes and models from general maintenance to performance. Whatever you need, let us know.
I have A few questions, I'm located in elmhurst and I have an Evo 8, When i shift at Redline , i Get locked out, i have to shift around 6700, or it wont let me in, Thats 2-5th gear, is that my Clutch or Snycros?
Question two, Im looking to get Gsc S2 cams And tuned on E85, Do you mind Pm'ing me a price?
My buddy Rocky had you Tune His Black SSL evo 8, awhile back, i liked the smooth & strong power!
The phones have been going crazy today, and we only have one person answering them - I was on the other line at the time. Sorry for the inconvenience. We'd be happy to help you, so please leave us a message next time or shoot us a PM with your phone number.
We're looking forward to doing the same with yours. You have a PM. Looking forward to seeing you soon!
We will have your stuff back from coating on Tuesday.
Also added some packages to post #1 check it out.
**Just updated**
- ARP main studs
Vic, Your upgraded SST clutches and SSP trans seal kit is here and we're looking forward to your appointment next week.
Ian, your trans tune is ready, we will see you soon.
