SS Brake lines
Old Apr 11, 2006 | 07:36 PM
KZEVO's Avatar
SS Brake lines
Have a question regarding stainless steel brake lines. I added the lines a few days ago along with new fluid (Motul RBF 600).
I've heard people say that SS lines makes you better modulate the brakes. My quesiton is does the pedal feel tighter and the travel less with SS lines or is there more travel?
The pedal doesn't feel spongy, but it seems like there's more travel in the pedal after installing the SS lines. I think the bleeding was done right, but would like feed back on your experience with SS lines. please be as descriptive as possible.
thanks
Old Apr 12, 2006 | 04:52 AM
djh's Avatar
djh
The lines have no effect on pedal travel, unless they're ballooning like a sausage casing! Since the compressibility of air is much greater than the elasticity of even stock lines, you need to make sure you've bled your brakes correctly to get any benefit from braided lines.
Dave
Old Apr 12, 2006 | 01:49 PM
Danny23's Avatar
ss lines should give you a firmer pedal as there is less expanding in the line when pressing the brake
Old Apr 12, 2006 | 02:53 PM
evojim's Avatar
I felt the same after the ss brake lines was intalled. The brake pedal needed to be pressed more before the brakes engage. Also, there seems to be more travel with brake pedel.
I installed stoptech ss brake line and used Motul RBF 600. I am planning to bleed the brake system this weekend to see if this will help.
thanks
Old Apr 12, 2006 | 07:17 PM
KZEVO's Avatar
interesting because i have the same lines and same fluid. let me know if anything changes after your rebleed.
Old Apr 12, 2006 | 08:21 PM
Danny23's Avatar
when i installed mine the pedal was definetely harder than stock, i used goodridge fr and rear, stock fluid and the pedal always felt firmer in any driving situation
Old Apr 16, 2006 | 10:21 AM
evojim's Avatar
The brake pedal feels a lot firmer after the rebleed
Old Apr 16, 2006 | 03:02 PM
Barnettevo's Avatar
Did you do anything different for your re-bleed? Just bled my brakes, and the pedal is worse, spongy with lots of travel. Some people (and the service manual), recommend bleeding with the engine running. Did you try this?
Thanks!
Old Apr 16, 2006 | 03:12 PM
KZEVO's Avatar
That's good to hear. I need to get it done again
Old Apr 16, 2006 | 03:13 PM
KZEVO's Avatar
Thanks!
There may be a how to in here somewhere about the rebleed. But I would suggest you rebleed again. Perhaps the person pushing the pedal did not push it all the way down? good luck
Old Apr 16, 2006 | 03:26 PM
evojim's Avatar
there is a very good write up in the how to forum
Old May 16, 2006 | 08:20 AM
wi_whoami's Avatar
thanks
I had a similar problem and it turned out to be a line that was not 100% tight and had a VERY slow leak. After fixing that (it was a rear line), I re-bleed the rear brakes and now it is a very hard pedal and feels much better than stock.
Old May 16, 2006 | 08:31 AM
djtmotorsports's Avatar
Always re-bleed the rear brakes after an install like that. I find that you don't get all of the air out of the rears the first time. Start with the right rear (inside bleeder then outside bleeder), go to left rear, then right front, left front, right rear again and then left rear again.
Hope this helps
Darin
Old May 16, 2006 | 08:39 AM
naucrx's Avatar
I didn't notice a difference in my pedal either. I went with the Goodridge lines and RBF-600. But then between driving my Civic during the week, and my wife's Charger on Sundays I only drive the Evo 1 day a week...
The SS lines feel good, and the car stops great. I bled the brakes right after the install, and then again after I drove the car around and noticed no difference.
Old May 16, 2006 | 08:42 AM
wi_whoami's Avatar
Hope this helps
Darin
Thanks. I'll keep that in mind for the next brake bleed (do it after event track day :-)
Talon
11
Feb 24, 2014 05:38 AM
JDavenport
48
Oct 26, 2011 05:56 AM
Western_man
16
Sep 15, 2009 08:27 PM
c900t16
Nov 8, 2007 07:06 AM
ries
Sep 19, 2005 07:06 PM
