Slicks on the evo...
So im about to buy a set of Hankook F200 slicks for the evo. I've checked out all of the fitment issues and they look to be 3/4 of an inch smaller in diam than my RA-1's.
Question 1. Has anyone attempted to run a full slick on the evo?
2. Will the slicks rip appart my diffs?
3. If i can run a 1:02 with old full tread RA-1's.... 1:01 with new shaved RA-1's at lime rock ... what will the time drop to with a slick tire?
something makes me think that EVO+Slick= really fast.. 59's? 58's ?!!?
Ive rim the goodyear GC CS tires which is their DOT race version of their full slick (used in grand am). They come with two very thin circumpherential grooves that go away after the first session so they are pretty much a slick tire.
I think the biggest issue is actually managing the tire temp and pressures. The goodyear was designed for cars weighing between 2200 and 2500 which is just right for a fully stripped/prepped touring class race car. Unfortunatly since im running a pretty much stock evo the weight and power over heat them on a regular basis. But they are definitly grippier than a "normal" R compound like the RA1.
I would imagine this issue will be further exacerbated since the Hankook tire was designed for Formula ZETEC/Ford and other light open wheel cars which weigh in at ~1230lbs with a driver. Set those pressures much lower than whats normally used.
full slicks compared to the RA-1s should be good for ATLEAST 2 seconds up at LRP.
You shouldn't have a problem ripping apart your diffs with the slicks. You're not launching which I would think would put more strain on your diffs do to the snap and banging together of the teeth when you launch.
A full slick's life will be dependent on the compound, type of car, track ect..... I would be carefull with a slick unless you know it is normally ran on a heavy car like the evo. Just because the tire might fit doesnt mean it was designed for a GT or street car. As far as lap time decrease it also depends on how soft the tire is. It might be 1 second or 3 seconds but only last for 2-3 laps until the tire is overheated. It is too hard to predict for sure.
Also if the tires refered too here are designed for a formula ford, I would suggest NOT running them if you don't want them to get overheated and possibly fail in a very short time on a 3100+lb car.
Warrtalon ran the Kuhmo V710 DOT slicks on his lightly modified Evo 8 and pummeled a lot of very strong performers like Vipers and Z06s at a trackday not long ago. I can't remember the thread name. He had some shots of his car up on 3 wheels and said it handled incredibly.
*Edit* Found a thread, but it's not the track thread I was thinking of...just auto-x.
Well.... anyone know of a slick that fits a 17x9 wheel and can work with an EVO's weight? what about Dunlop... Michelin ? The Porsche cup guys run both of them and run 17 / 18's. My plan here is a tune my suspension for the remainder of the season and for my last two events buy a set of slicks and see what happens. I have a data logger and will be able to see the difference.
Also... the Hankook F200 is designed for formula cars. BUT the guy at Frisbyracetire told me a guy running USTCC tried them out on GT cars and the result was good. Dont make me go to the porsche forums and ask where to buy slicks !!!
Since you've been running Toyo RA-1's up till now, you should try the Hoosier R6 or Michelin Pilot Sport Cup. Either one will be light years ahead of the RA-1.
Emre
http://www.sascosports.com/products/...php?type_id=36
http://www.bobwoodmantires.com/yokohama/yokohama.html
Well... i figured it out myself. Porsche GT3 / Corvette guys run dunlop slicks on stock cars and cut huge time off DOT R's.
I found a video of a stock GT3 on Dunlop slicks running 2:10's at the Glen!
I think dunlop is the way to go.
try some advan a032R's b4 going to slicks. they can be heat cycled &/or shaved. got mine from tire rack ($144/each) as they are discontinued. they were replaced by the advan a048. they both have a treadwear of 60. if u want slicks go w/ Hoosiers...
