Coolant Temp and EvoScan
Old Jul 26, 2006 | 12:53 PM
ScrappyJack's Avatar
Question Coolant Temp and EvoScan
I noticed what seemed like high coolant temp values on a couple of logs. This morning, I started the car and logged as it warmed up. The logged value from EvoScan at "full operating temp" was showing as 206.9024F. The factory gauge reads as normal.
I have logged the car with a PocketLogger before and recall "full operating temp" as being closer to 180 - 190F so it looks like my displayed value is about 20F off.
Is anyone else experiencing the same thing? I know one person mentioned similar results here.
Has anyone compared to a PocketLogger to check the value from EvoScan?
Old Jul 26, 2006 | 01:54 PM
MalibuJack's Avatar
Yeah the value is off.. you can fix it in your XML Definition file.. I think the AIT value is off a bit too..
Old Jul 26, 2006 | 02:06 PM
taenaive's Avatar
Yes, they are off. I think you have to subtract -10 from the coolant temp value. and oxygen sensor reading is off too. you have to add +.1 to that. well... it was the result of experimenting with my pocket logger and evoscan.
Old Aug 14, 2006 | 06:31 AM
justchil's Avatar
Can anyone confirm these changes ^^. I'll keep searching but I'd like to at least get my coolant reading right
Old Aug 14, 2006 | 06:36 AM
evo 8 ya's Avatar
+1
Old Aug 14, 2006 | 02:14 PM
TTP Engineering's Avatar
How tough is it to change the XML formulas?
Old Aug 14, 2006 | 02:23 PM
Atlmethevo's Avatar
If you know XML it's easy I already changed it in mine.
Old Aug 14, 2006 | 03:41 PM
AlwaysinBoost's Avatar
it is extreamly simple to do. i know nothing about computers and I was able to change the timing value in the .xml file. So if I can do it, anyone can.
now the question is what new value or multiplier is the correct one to use???
Old Aug 14, 2006 | 03:55 PM
JohnBradley's Avatar
In the .xml there are formulas representing each sensor's output. When you open EVOscan you see them right before the "values". go into .xml and add or subtract as you see fit or have addl scan capability to know is correct.
Old Aug 14, 2006 | 05:58 PM
taenaive's Avatar
looks like that Eval formula is screwed.
Someone gotta know the right way to translate to Fahrenheit from this register reading.
LogReference="CoolantTemp" RequestID="07" Eval="((-1.468x+139.74)*1.8)+32"
Old Aug 14, 2006 | 06:41 PM
taenaive's Avatar
Okay, try this formula instead. I think it should be around right range if original formula was the close one.
Find this line LogReference="CoolantTemp" RequestID="07" Eval="((-1.468x+139.74)*1.8)+32"
and replace Eval with
Eval="((-1.468x+134.18)*1.8)+32
or
Eval="((-1.645x+139.74)*1.8)+32
Let me know which one works better
Old Aug 15, 2006 | 03:28 AM
justchil's Avatar
I'll try those although I don't have anything other logging device to compare my numbers too :|
Old Aug 25, 2006 | 07:13 AM
mrfred's Avatar
Any news on determining the correct conversion forumula?
Old Dec 1, 2010 | 01:23 AM
nonschlont's Avatar
had 2 revive this 1 as Im experiencing the same issue. 203*F @ idle...
Just had a turbo and o2 (recirculated) installed today.
Last time I logged coolant temp, (while back) it was ~ 180 ish @ idle and have seen 162*F while cruising/on dyno, but wouldnt go lower than 188*F tonight while cruising. (~50* outside)
temp guage on dash is normal.
MUT 07 (0x6A47), Eval = "x*1.8+32", metric eval = "x", unit = "deg F", metric unit = "deg C", guage/chart min/max = 190
does this look about right?
Old Dec 1, 2010 | 03:41 AM
mrfred's Avatar
Wow, this is very old history! The correct scaling formulas were determined long ago. You should be logging coolant temp on MUT10 or MUT11 (one is IAT and one is coolant temp, but I forget which is which). What version of EvoScan are you using?
