ECU Locked
Old Sep 30, 2006 | 06:37 AM
11SECEVO's Avatar
ECU Locked
OK, went to a friends house to have my Launch Limiter Raised and a few other things downloaded and he could NOT download!!
This is on a New Bone Stock IX! Now Evoscan worked fine in reading the ECU so it WAS connected OK..he just keep getting an Error Message saying check cables etc. I did a search and came up empty....Ideas????
This guy is an EXPERIENCED Tuner/Flasher (Alwaysinboost on the board) and he NEVER saw anything like this before -- Ideas????????????
Thanks In Advance
Old Sep 30, 2006 | 06:49 AM
11SECEVO's Avatar
Anyone??
Old Sep 30, 2006 | 08:11 AM
skiracer's Avatar
I had a similar problem. I found out my problem was that i had a loose cable in my OBDII port. You might wanna double check to see those cables are securely connected to the port.
Old Sep 30, 2006 | 09:37 AM
11SECEVO's Avatar
Guys...EVOSCAN worked PERFECTLY! So EVERYTHING was Seated Properly!!
Anyone Else!!!
Old Sep 30, 2006 | 03:11 PM
JohnBradley's Avatar
If there is a comm error its because its not configured properly. EVOscan will configure automatically. Try setting the COM to another port or look and see whats there. It should show the cable if its working right. I havent encountered any problems downloading cars. I have flashed different ROMS (xml's) onto cars than they came with and had no probs.
Old Oct 1, 2006 | 02:42 PM
11SECEVO's Avatar
Quote:
Originally Posted by AlwaysinBoost
Both connectors were attached. I was able to D/L and read the stock rom with out any problems. Only when I went to reflash the ECU after adjusting the stationary rev limiter was the stopped in the middle with an error message... I've never experienced that before on any other EVO I've used it on, very strange.
OK Guy's There ya go...What EXACTLY has to be done to FIX THIS!!!!! I NEED to get this Flashed in the Next two weeks!!!!!!!!!!
PS. It's IMPORTANT to me and I'll GLADLY PAY to get it right!
ALSO the Entire EVO Comunity can benefit from the info as well!!
__________________
NEW EB IX delivered on Aug 4th
Old Oct 1, 2006 | 02:51 PM
inco9nito99's Avatar
Make sure in the Options>Port you click the openport 1.3 option. And then re-try, HTH.
Old Oct 1, 2006 | 04:06 PM
AlwaysinBoost's Avatar
everything was hooked up correctly because I was able to D/L & read the ROM image from the ECU. When I tried to re-flash the ROM with an adjustment to the stationary rev limiter it stopped in the middle and said there was an error and that I need to contact colby. Unfortunatley I installed the new version of ECUFlash since then and don't have a record of what the error actually was.
I wonder if anyone else experienced this before.
Old Oct 2, 2006 | 05:04 AM
11SECEVO's Avatar
Anyone....Malibu Jack...Come On guys i wanna get this dam thing Flashed!!
Old Oct 2, 2006 | 07:38 AM
11SECEVO's Avatar
Bump
Old Oct 2, 2006 | 02:28 PM
11SECEVO's Avatar
Afternoon BUMP!
Old Oct 2, 2006 | 06:14 PM
cij911's Avatar
Each ROM has its own definition so if you try using someone elses flash without chainging the ROM information I don't believe it will work. Per my earlier recommendation (different post) -- contact John @ Jestrtuning --- his email address is:
jestrtuning@gmail.com
Old Oct 2, 2006 | 06:35 PM
nj1266's Avatar
He never said he was using someone else's flash. He said he was trying to lift the rev limiter. But here you are accusing him of "using" another's flash. Why are you doing that?
Old Oct 9, 2006 | 12:38 AM
vboy425's Avatar
i know why nj1266, it's another newbie trying to act like he care or know what he's talking about and pointing people out but instead he end up making himself look stupid.
Old Oct 9, 2006 | 03:08 AM
HxllxMan's Avatar
Did you try to reinstal drivers/softwares?
CtSilver03Evo
Jun 13, 2012 06:53 AM
EatSleepBoost
May 18, 2011 05:13 PM
RoadSpike
Oct 23, 2006 02:00 PM
11SECEVO
Oct 2, 2006 02:30 PM
bez_bashni
Jul 19, 2006 03:34 AM
