short term fuel trims reading high
Old Oct 1, 2006 | 06:51 PM
cbrtrx's Avatar
my trims from evosan in the low load read around 125 to 135, mid and high stay around 100, ive been told that the evoscan fueltrims are off, ive also been told that the positive fuel trims wont affect my a/f while at wot as well even know that on other cars i know it does, any adivise on changing the trims closer to 100 or should i not worry about it?
Old Oct 1, 2006 | 07:21 PM
AlwaysinBoost's Avatar
do you have a wideband installed? what kind of readings are you getting while closed loop?
Old Oct 1, 2006 | 10:49 PM
cbrtrx's Avatar
car cruises and idles around 14.9 to 14.7, it runs fine but the fuel trims are alway around 125 to 135 on the evoscan in the low trims, acording to evoscan it reads to 200 which is probally +25 percent so im guessing 130 is around 6 percent fuel be added
Old Oct 2, 2006 | 10:20 AM
cbrtrx's Avatar
anyone??
Old Oct 2, 2006 | 11:40 AM
MalibuJack's Avatar
Thats roughly correct.. If its indicating the trims are +xx% then you add fuel, -xx% you remove fuel..
Only the closed loop fueling is a little counterintuitive, so it takes a little trial and error.. Generally trims are the difference in the desired fueling from the background map (open loop map at low load) and the ECU's attempt to maintain 14.7
For instance, if you disconnected the O2 sensor, the fuel adjustments you would make to get it back to 14.7:1 would result in a 0% (or 100% on Evoscan) fuel trim requiring very little work from the ECU to maintain it when you reconnect the O2 sensor.
Old Oct 3, 2006 | 02:29 PM
cbrtrx's Avatar
i sent you a pm
TravisF
May 9, 2012 02:48 PM
cbrtrx
Oct 10, 2009 01:29 AM
Charlie_B
Mar 2, 2008 05:30 AM
NIevo
Aug 12, 2007 05:45 PM
Oracle1
Jun 12, 2007 11:45 AM
