Load with GT-3076
Old Oct 17, 2006 | 10:29 AM
QuickOne's Avatar
Load with GT-3076
Hi all,
I have a IX MR that i am getting ready to install a turbo kit on. I have an AMS 3076 kit sitting here and am chomping at the bit to install it. However, i'm concerned about a lack of ecu support for the IX (and mivec)..
EcuFlash is quite interesting to me, but load becomes an issue. Since it will be using the stock MAF, i wanted to find out what people were seeing for load #s on turbo setups??
Any ideas?? I don't want to install this thing if i'm drastically over-running the maf. And since i do a decent amount of road racing, i need to make sure i have a safe tune..
Old Oct 17, 2006 | 10:30 AM
nutrulz's Avatar
Lack of ECU support? Have you even done a search?
Old Oct 17, 2006 | 10:37 AM
QuickOne's Avatar
Um, yes, I'm talkiong about real ecu support - not a hack (Utec, Xede). AEM doesn't have ems, motec is uber expensive, and Autronic hasn't released it yet. So, aside from goign full stand-alone, there's not much support for the IX. An VIII has just about whatever you want.
Old Oct 17, 2006 | 10:41 AM
Pure Playaer's Avatar
get an aem ems..
if u have a good tuner.. he can make it work with your ix..
some guy on this forum had n evo ix, and his tunner MADE an aem ems work =D
Old Oct 17, 2006 | 10:44 AM
AlwaysinBoost's Avatar
you really need to search more, there just as much support with ECUFlash for the IX as for the VIII.
You will have no probelms running that 3076 on the stock MAF/ECU. Lots of people including myself are running MUCH bigger turbos with great success.
Old Oct 17, 2006 | 10:49 AM
QuickOne's Avatar
Wow.. I never said that ecuflash wouldn't work. In fact, that's why i posted this question in this forum and asked about it and load and not "What ecu tool should i use"..
As for lots of people running bigger turbos, lots of people also have different maf settings and almost none have them on an IX. So, that's the reason for my questions..
Old Oct 17, 2006 | 07:50 PM
gogoevo's Avatar
270ish is the highest load i see on an 8 with 25 psi
Old Oct 17, 2006 | 08:00 PM
nobody is adjusting MAF settings, I don't know where your getting that information. You really need to search, as I said above, all your questions will be answered.
Basically as long as you have the correct data logging equipment you can tune the crap out of that turbo on a IX and make a ton of powr. Or pay a professional for the same result.
Old Oct 17, 2006 | 08:15 PM
Doogie Howser's Avatar
members have over 500WHP on the stock maf using a reflash so you should be fine with the gt3076 even with meth or with a race gas tune.
