Does anyone know who to read Ohlins/Eibach Spring Part numbers?
Old Jul 1, 2007 | 06:25 PM
dannykao's Avatar
Hello, did quite a bit of research on the net and the forum, but I am still not sure if I got the spring rate of my Ohlins coilover spring. The part is is H200-065-T100 26,06. Does it mean 200mm, ID 65mm, and 562lbs? Can anyone confirm? Thanks in advance. Danny
Old Jul 1, 2007 | 06:33 PM
hotrod2448's Avatar
I can look it up tomorrow at work. Our spring guru will know. I know if you are checking it on a spring rater Eibach uses a different formula than most manufacturers to calculate rate.
Old Jul 1, 2007 | 07:38 PM
bryant's Avatar
I know for sure on Eibach for example: 0700.225.0150
700 is the length. 7 inches
225 is the ID. 2.25 inches
150 is the srping rate in lbs. 150lbs/inch
Old Jul 1, 2007 | 09:16 PM
Yogi_B's Avatar
Looks like it uses the metric measuring system.
In that case the spring rate will be measure in newtons.
So for your spring it will be:
200mm long
65mm ID
100N/mm springs rate = ~10.19kg/mm = ~569.62lbs/in
So yes you got it right in your post.
Old Jul 2, 2007 | 09:24 PM
dannykao's Avatar
200mm long
65mm ID
Thanks Yogi_B. Definitely learned something on the spring rates today. Much appreciated. Danny
EVL4B11MR
Oct 26, 2016 06:05 PM
LCS
Jun 15, 2016 02:26 PM
butters149
Jan 19, 2015 09:07 AM
mot
Dec 2, 2008 08:37 PM
Richard 350z
56
Oct 26, 2004 12:05 PM
