Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
Painting stock wheels
Old Feb 11, 2008 | 01:58 PM
Gts_BlackJoker's Avatar
I was wondering if anyone had a guide or could make one about painting the stock wheels?
seems like an easy mod that could save a few hundred dollars for the time being that could be placed elsewhere..
Old Feb 11, 2008 | 02:54 PM
Blacksheepdj's Avatar
1. Remove wheel
2. Clean wheel
3. Sand gently
4. Paint wheel with a light coat of primer, let that dry
5. Repeat
6. Repeat again
7. Paint wheel with a light coat of paint, let that dry
8. Repeat
9. Repeat again
10. Repeat again
11. Paint wheel with a light coat of clearcoat, let that dry
12. Repeat
13. Repeat again
14. Put wheel back on car
Old Feb 11, 2008 | 03:27 PM
Something a bit more detailed? Perhaps pics and such...
Old Feb 11, 2008 | 03:40 PM
razo's Avatar
pictures won’t really help much more…blacksheep pretty much nailed it. lol
some extra notes, if the tires are taken off it makes for a much easier job…if not, do a good job of taping them up.
other than that – just take your time – sand evenly, don’t rush in between coats, let everything dry, don’t spray too close, make sure you keep a good distance and a steady stream of primer/paint/clear coat when you are applying it, constantly shake the can between sprays…not really sure what else to say…
good luck
Old Feb 11, 2008 | 03:44 PM
Or, instead of taping, get a pack of note cards. Stand them up in the wheel/tire gap all around. Quick and easy. A great idea my buddy came up with.
Old Feb 11, 2008 | 03:50 PM
Okay, I am going to test my luck with this project.
Old Feb 11, 2008 | 03:54 PM
mitsuboost30's Avatar
DONT PAINT... POWDERCOAT EM!.. its like 400 bucks
Old Feb 11, 2008 | 04:26 PM
nunyas's Avatar
painting isn't too bad... I wrote up a wheel painting article on a different forum I'll post a link here.... it's long and fairly detailed... It could be more detailed, but I think it's good enough. There are paints out there that are "formulated" for use on wheels that are supposed to be more resistant to brake dust and "special" wheel cleaners than regular paints. I talk about the paints I used on the wheels I painted in the article:
http://www.britishcarforum.com/bcfor...438#Post311438
The paint held up well on those wheels. If I were to paint wheels again, I would go with the same paints... Mind you, I painted raw/bare aluminum wheels. So, the use of "etching primer" may not be needed in your case.
Old Feb 12, 2008 | 01:56 PM
midunn's Avatar
^Nice write up nunyas, I'm going to do this just to fix some curb rash that I have on one of my rims. I'll just do the area I need fixed and hopefully I can find a silver paint that matches the orginal GTS wheel color.
Old Feb 13, 2008 | 02:53 PM
g.romay's Avatar
if anybody has done this please post some pics, id like to see how the stock wheels look painted. thanks
Old Feb 13, 2008 | 05:19 PM
nunyas's Avatar
If you're doing touch ups on your wheel, there's a tutorial floating around the net that I've seen where a guy does a curb rash "touch up" on one of the wheels on his Porsche with the wheel still on the car... ah! just found it!
http://www.bmwtips.com/tipsntricks/w...uff-repair.htm
It's quite a different from what I did in my article. I started with old **** wheels, and basically did a full resto on them.
Old Feb 13, 2008 | 07:24 PM
Check this thread. Guy did a great job.
https://www.evolutionm.net/forums/sh...ht=gold+wheels
Old Feb 13, 2008 | 07:49 PM
MLancer's Avatar
Painting stock wheels-car-tire.jpg Painting stock wheels-car-perspective.jpg
Here's Powder coat black for ya..
Old Feb 13, 2008 | 08:04 PM
cspec's Avatar
STOP DONT PAINT........it will void your warranty..HA.. good ol'
Old Feb 14, 2008 | 05:31 AM
rav's Avatar
rav
When you do go to buy the paint, they have this red nozzle thing that fits on top of the spray can. I suggest you get that; It's only a few bucks and it saves you from breaking your fingers off while trying to empty 8 cans of paint.
edit: I also have a question about painting since I'm considering it too.
What would be a good outside temperature to do all this work?
What do people think about flat black v. semigloss black v. gloss black on a blue gts?
Thanks everyone.
