HKS EVC 6 Installed... But..
Old Nov 8, 2008 | 07:31 PM
dankaristo's Avatar
just got through installing the evc on the evo.
Basically the only problem is that I have the fast key system so I cannot tap into the ignition for the 12v power source.
I need a constant 12v line in the engine bay that is off until the car is turned on. If there is a source in the fuse box in the engine bay that would be perfect.
Thanks guys,
Brian
Old Nov 8, 2008 | 07:33 PM
Wicked E's Avatar
Cig lighter?
-E
Old Nov 9, 2008 | 04:59 AM
Dyno4mance's Avatar
Just use an add a circuit and pull from another switch 12 in the cabin, you already ahve the lines from the display unit running to the solenoid so just follow the same route.
I run all my gauges and gauge control box off an add a circuit on the instrument cluster fuse.
Old Nov 9, 2008 | 07:47 AM
rtremaine's Avatar
Thanks guys,
Brian
fuse 22 in the engine compartment fuse box is the cruise control and is switched
by the MFI "injection" relay. Might want to look at that.
Old Nov 9, 2008 | 09:58 PM
dankaristo's Avatar
ok i will take a look at it. I know cig lighter should work but I would need the wire traced.
Derek888
22
Sep 1, 2013 08:56 PM
silex
Mar 7, 2006 08:46 PM
RS2
Dec 3, 2005 10:00 PM
NYEVO8
Nov 21, 2004 09:14 AM
Ironman
Nov 9, 2004 04:31 PM
