MR with MBC
MR with MBC
Hi,
hopefully I'll be getting my pkg from TTP bext week.
- Zchip
- Unos MBC
- Prosport premium boost gauge
- Eibach pro kit
i have zero experience with MBC, how do you set the boost with MBC and make sure it is correct on Evo X SST?
- Zchip
- Unos MBC
- Eibach pro kit
You want to make sure you have a boost gauge to prevent running too much boost.
Hook up the MBC between the pressure side vacuum line and the turbo actuator. Turn the MBC to the lowest boost setting (usually counter clockwise) and drive in 4th gear from 2500-4000 RPM (uphills is best) at WOT. Check your highest boost, should be around 12 psi. Gradually increase the boost (turn clockwise) and repeat until you hit your target boost (25psi).
