ECUFLASH + MBC or EBC
Old Feb 15, 2009 | 10:30 AM
EVOXSILVER's Avatar
Please is there any way to prevent the car from going into limp mode or shoot SES at part throttle?
If it can help i've noticed that limp mode will occur only when my HKS BOV is installed. If i go back to stock BPV it will only shoot the SES.
I guess that the spring in the hks BOV is really tight and under certain conditions as part throttle the way it closes the valve will cause some kind of over boost. Hope to hear from you guys soon.
Old Feb 15, 2009 | 12:38 PM
Colin's Avatar
Why don't use stock boost controll? It works better with stock ecu and limiters and is fully tuneable.
Old Feb 15, 2009 | 06:04 PM
jmorris1027's Avatar
soo..if it only does it when the hks blow off valve is installed....take it off???? the stock valve works just fine.
Old Feb 15, 2009 | 07:37 PM
hawaiian_evo's Avatar
i know boost can be controlled by ecu but if youre one who has alky and runs 35 psi but some days want to run just 15ibs to be safe then wat?
thats the only reason i wana use my avcr... to have the control to change my boost setting with a bush of a button
Old Feb 15, 2009 | 07:50 PM
EndlessRed's Avatar
if you're thinking of pushing the limits and have something that you can control on the fly, then EBC is the way to go.
Old Feb 15, 2009 | 08:04 PM
Bggstin's Avatar
You could run the dual stage manual like Buschur has. I find that more reliable than EBC's. I didn't like my AVC-r one bit on my eclipse.
Old Feb 15, 2009 | 08:16 PM
EndlessRed's Avatar
what's dual stage manual? that's the first i heard of it.
Old Feb 15, 2009 | 09:52 PM
EVOXSILVER's Avatar
Thank you very much hawaiian_evo for your understanding.
It's fun to notice that a lot of people don't even want to help you. When i first posted my question i was telling myself "ask the community they know much more than yourself" but it seems that i was wrong.
I know that HKS BOV makes the problem to occur and that i should take it off but i also know that stock BOV is good for 25 psi and beyond that point it might be leaking.
I know that stock solenoids can control boost but i really like the idea of having a solution for : everyday use, when my wife drives the car, cold nights with hot hondas...
Anyway i found a part of answer to my question from Burnings and Gunzo (Thank you):
By lowering the passive wastegate duty cycle by 40% in every 3 maps, by raising the boost limits to 319 in every cells and raising the load offset to 500 instead of 80 (stock) i didn't have any SES or limp mode.
Old Feb 16, 2009 | 08:36 AM
Yearlongstorm's Avatar
Sooooo, was it the BOV? Where you VTA? Did you keep it off?
Old Feb 16, 2009 | 08:40 AM
Psquared's Avatar
Interesting and good to know about the tables. I'll have to pass that on to a local X owner here. We put an MBC on his, and it would go into limp mode every time. Recently, we were diagnosing a forge wga "problem" and it turned out it was the greddy bov. We put the stock bov back on and his overboost issue was cured, and it doesn't go into limp mode anymore. His car with the greddy bov was hitting 30psi without an issue. Kinda scary.
Old Feb 16, 2009 | 09:27 AM
Rob@cobbtuning's Avatar
There are devices that allow you to have multiple tunes, not just boost profiles, ready to change at the press of a button. Said device also allows you to custom tune your own vehicle.
Cheers,
Old Feb 16, 2009 | 03:46 PM
Cheers,
would that device be a cobb AP? if so woot i just bought one
Shane Anderson
Feb 3, 2014 07:26 PM
MurderedOut09
Dec 12, 2013 05:38 PM
2010 Rallihead
10
Dec 7, 2010 07:11 PM
hediki12
Apr 25, 2010 09:40 AM
Sevi_EvoX
Oct 5, 2008 07:30 PM
