O2 location for logging
Old Jun 9, 2009 | 09:46 AM
GTR2009's Avatar
where can I install the innovate O2 sensor on evo x for logging ?
Do I need to drill a new hole in the exhaust or I can use the first O2 location?
Thanks !
Old Jun 9, 2009 | 09:50 AM
goofygrin's Avatar
If you pull the primary o2 sensor your car won't run for ****.
You can use the secondary o2 sensor bung, but your car will throw a code (likely P0420) -- although it won't hurt the car or cause it to run funny.
I recommend welding a new bung on the car and using that. It needs to be in the 9oclock to 3oclock position (not hanging down).
Old Jun 9, 2009 | 09:54 AM
GTR2009's Avatar
and where should I weld the bung? before or after the first O2?
On subaru's I used the secondary O2 location and disabled rear O2 with ecuflash
Old Jun 9, 2009 | 10:24 AM
crcain's Avatar
Most widebands suggest a location at least a couple feet from the exhaust port outlet. Read the instructions that came with your wideband. I highly recommend choosing the location carefully and make sure you weld the bung in a place that is as easily as possible to get at. Mine is about in the middle of my downpipe.
Old Jun 9, 2009 | 11:11 AM
goofygrin's Avatar
Mine is on the test pipe since it's easier to get in and out that the o2 housing/downpipe.
Right now, you can't disable the rear o2 sensor on the x's, otherwise you could do just as on the scoobies.
Old Jun 9, 2009 | 11:52 AM
GTR2009's Avatar
in the innovate lc-1 manual they say that if you place the WB on the downpipe it can be damaged by the heat generated by turbo
Old Jun 9, 2009 | 11:58 AM
crcain's Avatar
Innovate will say all sorts of crap like you need to use some sort of extender instead of the bung that _they_ ship with the kit. I think utimately the further away you are from the exhaust ports the better it is for the life of the wideband but your readings will have a bit more lag when doing logging from the actual ignition event that created the exhaust pulse.
I made the mistake in saying where I put my sensor for my VI. So for a X use your best judgement and find out the easiest place... downpipe, test pipe, etc.
haxr303
Jul 3, 2016 07:50 PM
EvilEvolution8
Dec 11, 2015 01:51 PM
evo jason
Jan 7, 2012 04:25 AM
awdboosted
Oct 8, 2009 09:58 AM
racer135
Jul 18, 2008 06:42 AM
