any power to be had going from 10.5 to 11.5 afr?
Old Aug 15, 2009 | 03:56 AM
leecavturbo's Avatar
my afr falls from 11.0@4k to 10.3@the top
much gain to be had from leaning up?
Old Aug 15, 2009 | 04:43 AM
recompile's Avatar
Definitely. Depending on how aggressive your timing map is, you may need to dial back a degree or two when you take out that much fuel, but it will net you gains upwards of 20whp
Old Aug 15, 2009 | 04:51 AM
ok thx
Old Aug 15, 2009 | 09:48 AM
GST Motorsports's Avatar
20whp from just changing fueling from 10.5 to 11.5 afr? Is that what you are saying?
Old Aug 15, 2009 | 11:39 AM
nothere's Avatar
it will save you some gas. and in my experience the car will feel better.
depending on the afr I have seen 5 mpg up to 8 mpg on a race track. the 8 might be responsible for the new motor though.
Old Aug 15, 2009 | 12:03 PM
EVOIXreno's Avatar
there is actually no definite answer... it's here in Reno I can tune for 11.5 but I don't gain any power going from 11.1 to 11.5.. even with adjusting timing. so you might be able to lean it out some and add 5- 10 whp but 20 is a considerable amount. just my .02
Old Aug 15, 2009 | 05:33 PM
JohnBradley's Avatar
anything under 11 will lose power unless its spraying methanol at the same time. 11.0-11.5 is about a draw, but a little leaner starts to pick up a little power. I wouldnt quite say 20whp, but 10whp definitely.
Old Aug 15, 2009 | 10:36 PM
TTP Engineering's Avatar
Leaner is meaner as long as the EGT is under control.
What is the octane?
Old Aug 15, 2009 | 10:47 PM
crewdawg130's Avatar
What is the octane?
Thats old school i like that!
whats next " If you aint knocking you aint rocking"
its the UK so it cant be much oct
Old Aug 15, 2009 | 11:05 PM
Typically 98RON is 92.5R+M/2 USA method.
Old Aug 15, 2009 | 11:15 PM
when i was in germany, might as well put moon shine in my silvia but yes in kindda 93
Old Aug 16, 2009 | 12:53 AM
uk vpower which is iirc 98ron? uk spec
Old Aug 18, 2009 | 12:01 PM
HermaN's Avatar
UK Shell V-Power is 99RON according to Shells website.
Old Aug 22, 2009 | 08:42 AM
sponners's Avatar
yep, vpower is 99ron (sure it says on pump)
we also have tesco99
and bp 102 (but that is way too expensive)
mithrandir7533
Nov 24, 2020 12:40 AM
lancerrally45
May 31, 2016 11:09 AM
EvoIXPilot
Apr 12, 2013 09:56 AM
ctfpevoVIII
Feb 8, 2012 07:04 PM
JoeBee
Aug 5, 2007 01:15 PM
