Led Tail Lights, Help w/ install
I purchased the 2008 Led Tail lights from RRM and got them yesterday, installed them and they seems to be working perfectly, then it turned to night and i realized that when i had my headlights on my taillights were still off and wouldn't turn on. Has anyone bought and installed these tail lights yet and have you run in to any problems?
dude i been bought those tail lights and i just installed them for the summer. i got the same problem , the freakin night lights work but the brake lights dont work at all. i mean the third brake dont work or nothing. put back in the stock bulbs and i gots the same problem. Mad As Hell!!! can someone help me out plzz
Bump....Chan, can you share the details???? Mine came with load resistors built in, everything works great except the night time lights. My fuses are fine, and when I put the OEMs back on, they worked fine....any help would be most excellent guys/gals.
If your third light do not work mens your STOP fues is busted. It is located on the driver's side right under the steering column. look for stop fuse, I am sure it is busted. also I am 100% sure that your cruise control is not gonna work either.
Good luck
Good luck
