Led Tail Lights, Help w/ install
When I put my old tail lights back in, everything worked fine including CC and my 3rd brake light.
i am having this same problem
my left corner left trunk doesnt work right corner and right trunk light works.
what do i need to do or switch around to get this to work?
i blew a fuse lol luckily i have some extra.
it sounds like you are not impedance matching properly. if the computer doesnt see the 'same' load for the lights it might think it is blown and that's why things would stop working. you may need to put a bigger resister in line with the led tail lights in order to trick the computer into thinking that there is a light there.
with out being able to test and play, any suggestion would be a shot in the dark. if you have a digital multi meter, compare your old lights with the new ones. You should see the same resistance across them. if the led lights have less resistance, than that could be the cause because less resistance will cause more current causing your fuse to blow. (I = V/R) gl
Briggamortis
Jan 17, 2016 05:31 PM
Jp7
May 2, 2012 03:12 PM
gridiron44
Jun 5, 2010 10:30 PM
