Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
Led Tail Lights, Help w/ install
Old Aug 25, 2009 | 11:17 PM
|chan|'s Avatar
I purchased the 2008 Led Tail lights from RRM and got them yesterday, installed them and they seems to be working perfectly, then it turned to night and i realized that when i had my headlights on my taillights were still off and wouldn't turn on. Has anyone bought and installed these tail lights yet and have you run in to any problems?
Old Aug 26, 2009 | 04:15 AM
bmoresauter13's Avatar
How they look? Do they look good even though they dont work at night? got any pics of them? id like to see how they look, i couldnt tell what could b hte problem either
Old Aug 26, 2009 | 11:02 AM
|chan|'s Avatar
got a few pics, so i went and messed around with the lights again and i got everything to work except it keeps blowing the brake/stop fuse.
Old Aug 26, 2009 | 12:44 PM
|chan|'s Avatar
ahaha all fixed wow i feel retarded. Thanks Brian @ RRM for you words of wisdom, i found one of my connections was reversed.
Time to go buy 3 15A fuses lol
Old Aug 26, 2009 | 12:49 PM
Greedy_son's Avatar
^ Which ones did you get? Smoke or gun metal.
They look pretty good on a OB. Can you take night shots when you get the fuses back in.
Old Aug 26, 2009 | 01:42 PM
Slyy's Avatar
^^ looks good. Wanna see them at night also!
Old Aug 26, 2009 | 09:36 PM
|chan|'s Avatar
Umm on the RRM site it's listed as the black ones, from what I can tell the housing is black and the lense is clear. I'll take some night pic tonight and post them up.
Old Oct 23, 2009 | 05:59 AM
FireFighter2968's Avatar
night pics?
Old Oct 28, 2009 | 12:14 PM
CMcraz23's Avatar
bump for NIGHT Pics!!
Old Oct 28, 2009 | 07:12 PM
dj xs's Avatar
those just down right look like **** money ill spent id rather spend that much on da ones with the black housing.....:
Old Nov 5, 2009 | 09:23 AM
ara606's Avatar
Any cruise control issue?
Old Mar 18, 2010 | 05:49 PM
Ravishinrick's Avatar
dude i been bought those tail lights and i just installed them for the summer. i got the same problem , the freakin night lights work but the brake lights dont work at all. i mean the third brake dont work or nothing. put back in the stock bulbs and i gots the same problem. Mad As Hell!!! can someone help me out plzz
Old Apr 8, 2010 | 06:18 PM
xw09gts's Avatar
i have the same problem is there any one that can help
Old Apr 11, 2010 | 09:31 PM
UnderCover's Avatar
Bump....Chan, can you share the details???? Mine came with load resistors built in, everything works great except the night time lights. My fuses are fine, and when I put the OEMs back on, they worked fine....any help would be most excellent guys/gals.
Old Apr 13, 2010 | 01:05 PM
ara606's Avatar
If your third light do not work mens your STOP fues is busted. It is located on the driver's side right under the steering column. look for stop fuse, I am sure it is busted. also I am 100% sure that your cruise control is not gonna work either.
Good luck
